Topic: Fireface UFX+ first time recording on usb stick - standalone
next Saturday I'd like to use my UFX+ to record a piano solo in standalone mode, with no computer connected.
I think I'll be using three condenser mics.
This would be my first time and I'd like to hear any advice from you who have had experience  with such setup.
Many thanks,
Luca
www.unguitar.com
https://linktr.ee/lucaformentini
2 (edited by ramses 2022-02-03 19:15:41)
Re: Fireface UFX+ first time recording on usb stick - standalone
Hi Luca,
Ok, become acquainted to DURec and pre-test 1st.
Prepare a setting for this event with a PC connected.
Manual links:
https://www.rme-audio.de/downloads/fface_ufxplus_d.pdf
https://www.rme-audio.de/downloads/fface_ufxplus_e.pdf
Tip: in TM FX there is often a little problem, that you can't see/find the button "Record view", see manual ch 38.2, when all submenues are open (View Options, Snapshots, Groups, Layout Presets, DUREcorder).
My recommendation is that you collape e.g. groups or layout presets, which might be used more rarely.
Then you can select "Record View" to mark DURec record and playback channels.
I wouldn't select all possible channels and only record those that you actually need.
Then you can record more on your stick and the 2GB file extents contain a larger time frame.
One DUREc file can at max be 2GB long, if needed up to 100 become written.
So the max file length / disk space of one recording can be 200GB in total.
But relax for a few channels and a few hours of recording you won't reach that ... wink
Then you can store the current routing including DURec / Record View settings to one of the six user presets:
TM FX -> Options -> Store current state into devices -> Setup 1 .. 6
In standalone mode you can recall these settings on the UFX II/+, see manual ch 23.3:
Setup/Rev -> Setups -> Load all Settings -> Setup Select 1..6
Or modify and store into another setup ...
Also pre-check whether your pen device is able to record the number of channels without problems.
Observe USB load when testing, see manual chapter 38.5:
USB load should exceed 80% only for a short time.
I made good experience with the Sandisk Extreme, which was proposed by Matthias Carstens and also with the models with even higher capacity (128 and 256 GB).
https://forum.rme-audio.de/viewtopic.ph … 42#p175442
thank you!
this means that if I want to use DUREC I must setup the recording settings with a computer connected first and create a "scene" to recall when I want to use the interface in standalone for DUREC.
Did I get it right?
www.unguitar.com
It's easier to prepare this with TM FX.
Pls check the manual on your own, how you can do this in channel settings.
I just found it intuitively at the device in less then a minute.
yes,
Ramses, I checked the manual, still I have a couple of questions:
-how do I switch phantom power on via the interface?
-what does "AS" mean on the interface display beside the mic gain?
I wasn't able to find these answers on the manual, sorry if I missed something...
thanks again
www.unguitar.com
6 (edited by ramses 2022-02-03 22:24:25)
The documentation of the submenues in the manual in ch 23.2 is terse, nevertheless it's guessable that the CHAN/Mix button leads to channel settings:
1. Push CHAN/Mix
2. turn Encoder 1 to select the desired (Mic) channel
3. optionally turn Encoder 2 to select the "Settings" submenue
4. push Encoder 2 to scroll down the menue list to find the entry "+48 Volt"
5. turn Encoder 2 to turn 48V (phantom power) ON / OFF
AS is there an abbreviation for Autoset, see also manual ch 19.2.
that's all!
many thanks and sorry for the bandwidth waste.
www.unguitar.com
8 (edited by ramses 2022-02-04 08:50:55)
Unguitar; Luca Formentini wrote:
that's all!
You're welcome, if you have any further question, don't hesitate to come back.
The references to manual has the intention to show, that it is indeed very useful.
