1 (edited by Motix 2022-03-03 23:52:20)
Topic: UFX+ wont work after re-power it
When i turn my UFX+ off and then turn it on, it won't work, the pc wont recognize the UFX+.
I need to restart the pc for it to work again
Also, if i turn on the pc before the UFX+ is on, the pc wont recognize the UFX+.
The UFX+ needs to be on before i turn on the pc...
I tried setting the "tounderbolt" option in the settings from "auto" and the problem still occur. I installed the last driver.
What should i do next?
Thank you
Re: UFX+ wont work after re-power it
I edited the massage. Sorry for the bad english
3
Which firmware version is in the UFX+?
Also please try to unplug TB and replug instead of restarting the computer.
I updated now the firmware to the latest version and now it sometimes works and sometimes doesnt.
Repluging the cable didnt help. Its the same problem
5 (edited by Motix 2022-03-05 00:12:56)
The RME  Support replied me this message:
"this is a PC/Thunderbolt issue, not one of the UFX+. TB is not Plug&Play like USB. This won't happen with a USB connection."
I have the Asus ThunderboltEX3 card. Can you please tell me how to configure it well? What should i change in the Bios?
Im adding a picture of my ThunderboltEX3 bios settings:
https://gcdnb.pbrd.co/images/fQAPUdUxiw4Q.jpg?o=1
6 (edited by Thermaltake 2022-03-05 08:58:52)
Remove the TB cable and connect your UFX+ with PC with USB Type-B to Type-A cable. No need for any bios change there.
7 (edited by Motix 2022-03-05 09:11:47)
I know i can use the usb cable but i need the Thunderbolt to work.
Does Anyone have experience with that issue? What should i change in the bios settings?
Maybe try flashing latest bios, and see if it makes any difference.
Thank you
I just did it. It didnt help.
Any other suggestions?
10 (edited by purebits 2022-03-06 10:27:00)
tried with another, higher quality, cable?
I connected it with the cable that came with the UFX+ and I have a really good adapter that i bought from Amazon with great reviews.
A cable like this costs about 120$. I dont want to buy another one. Maybe its someting to do with the thunderboltex3 bios settings...
12
The UFX+ does not come with a TB cable. What 'adapter' and cable are you talking about? Please provide Amazon links.
13 (edited by Motix 2022-03-26 09:22:19)
Youre right. I forgot that the UFX+ doesnt come with a TB cable.
Links:
Adapter:
StarTech.com Thunderbolt 3 to Thunderbolt 2 Adapter - TB3 Laptop to TB2 Displays/Devices - Thunderbolt 2 20Gbps or Thunderbolt 1 10Gbps Converter - TB3 Certified - Black - Windows/Mac (TBT3TBTADAP) https://www.amazon.com/dp/B019FPJDQ2
Cable:
StarTech.com 2m Thunderbolt Cable - M/M - Thunder Bolt to Thunder Bolt 2 Meter Cable - M/M (TBOLTMM2M) https://www.amazon.com/dp/B0084L74EW/
14
Ok, that adapter is the reference. In that case I have currently no idea what is causing this.
Thank you for trying to help.
Can someone help me look for a solution in the internet?
Theres gotta be someone who has the same problem.
i dont know where to search, which forums ext
