basementstudio wrote:With an aggregate device on a Mac, is there a way to route the ADAT channels from the Digiface USB directly to the main output of the Fireface UFX?
(Opposed to route the ADAT channels to inputs of my DAW, Logic for example, and the route this within the DAW to the output, which causes additional latency and uses processing power ...)
Thanks!
Only if you make a direct connection, so one of the digiface adat outs to the ufx,
I have that with a hdsp9652 and a babyface pro fs. Works perfect. but on PC so no aggregate, just as an extra to the hdsp, which I use for asio driver. The baby as HQ DA.
If only for auditioning you can also use the digi headphones out to the UFX analog in. But remember they have to be synced anyway so you need at least one adat connection from the master to the slave.
