Topic: Babyface Pro output problem
Resurrecting this topic...
I am currently having the same problem here with my Babyface Pro.  System was working fine two days ago, then when I fired it up today, channel 1 is far lower than channel 2. Checked the pan/balance in TM and it was right down the middle the way it should be.  This issue happens with internet audio also... I swapped out the cables and problem still exists.  Any thoughts?
Thank you...
2 (edited by waedi 2022-03-17 02:48:46)
Re: Babyface Pro output problem
Did you perform also a speaker swap test ?
I mean left speaker connect to right and right speaker connect to left ?
And with headphones ? Are there both channels equal ?
A screenshot of your Totalmix may be helpful too.
