Topic: Babyface Pro output problem
Resurrecting this topic...
I am currently having the same problem here with my Babyface Pro. System was working fine two days ago, then when I fired it up today, channel 1 is far lower than channel 2. Checked the pan/balance in TM and it was right down the middle the way it should be. This issue happens with internet audio also... I swapped out the cables and problem still exists. Any thoughts?
Thank you...
