kelfar wrote:MC wrote:Ok, clicks on unused hardware output channels. What about the USB errors and the syncing state/only UFX+ test?
I think I found the problem. First, thanks for your replies. Second, the USB 3 cable was connected to the front panel USB 3 which was creating a USB [error]. I did plug the USB 3 in the rear and so far no errors have been reported. Most importantly, I do not hear the burst/click anymore. However, I will keep watching if the issue comes back.
Nice that you found it, but I am really wondering how you could mix-up these ports.
The front has no USB3 connection, it's an USB2 port dedicated for DURec, so that you have it easier to plug and unplug memory/storage devices, therefore this port is labeled "memory".
The USB3 port for connecting the computer is clearly visible at the back and labeled "USB" and it has the typical shape of an USB3 type B plug.
The purpose of each of those ports is explained very early in the manual on page 9 an 10. Maybe worth a look for these and other things. When I wait for the delivery of new hardware I have always a look into the manual to become familiar with new devices and then you can deploy faster and better.
BR Ramses
UFX+, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1650v4, Win10Pro21H2, Cub12Pro
