Topic: MADIface PRO FX send not working
I've had the MADIface for quite some time, but have never had to use the FX before. I'm using it with a windows 10 laptop with the PSU provided by RME.
I have a mic going into AN1 set to mono. Signal present. I wanted to add some fx for phones cue.
I have the channel routed to ph3/4 for monitoring. No problem. I hear the mic source perfectly.
I turned the FX fader send all the way up on AN1.
I make sure the FX are on.  I check the FX meters. No movement on the FX meters. So, this appears that the send on AN1 is not getting to the FX input. I should be seeing some meter action, correct?
Re: MADIface PRO FX send not working
Please download this version of TM FX:
https://www.rme-audio.de/downloads/tmfx_win_176.zip
Exit TM FX and overwrite TotalMixFX.exe in Windows\System32 with this file, then start it. This is a release version that unfortunately is not yet available in a driver package.
After you install that version of TotalMIX FX that Matthias showed you, make sure you turn up the return on whichever output you're listening to (phones, main, etc.)
-Steve
