Topic: Babyface (blue) Headphone Ohm value
Hello to the round.
I would like to use the old Babyface's headphone output as a line output via the break-out cable and at the same time use the headphone jack on the Babyface itself as a headphone output. The signals are not electrically separated, so they are identical. Which impedance, i.e. which ohm value should the headphones ideally have in order to avoid extreme volume differences? I have a choice between 150 ohms and 32 ohms for the headphones. Which one will work better here. Listened to is more speech, less music. Thanks for helpful tips and explanations. Greetings weynisse.
