Topic: Settings blurry on 125% scaling
Hi, when I bought new monitor scaling went from 100 to 125% by default. And I noticed that my UCX Settings are blurry, Totalmix is looking normal. Is there any fix for that ?
RME User Forum → FireWire & USB series → Settings blurry on 125% scaling
Anyone with same issue ?
I never use scaling
I never use scaling
+1
The usual thing with most stuff when performing scaling. Therefore I prefer to buy screens where screen size and native resolution match - as good as possible - to get a screen which is useable for work and does not overstress your eyes.
For Full HD resolution (in this case 16:10, 1920x1200) I am using for example an EIZO EV2457 24" with 94ppi.
Then you can comfortably read everything on screen in native resolution.
RME can you fix scaling in settings somehow ?
it's your display settings not the RME settings. something to do with your native resolution and display size/scale. what does that box look like when you set it to 200%?
you could also try to turn off smoothing but I can't remember where that is in windows. it's one of the things you can turn off to improve performance too.
How come totalmix looks normal then ? When set on 200% it doesn't look blurry same as on 100%. It's not because of display, it is because RME settings doesn't support scaling on that level like Totalmix do.
I tried that option it is in display settings in scale and layout - advanced scaling settings, I turn it off but it is the same so I put it back on.
