Topic: ADI-192 DD : AES/EBU Sample Rate Conversion w/ Different Input Rates
With the ADI-192 DD, it it possible to have 2 different sample rates coming from separate AES/EBU sources input simultaneously and converted to a common AES/EBU output sample rate?
In other words, if I have one AES/EBU device output at 48 kHz and a second AES/EBU device output at 96 kHz, can I have both input into the ADI-192 simultaneously and have the AES/EBU output for both as 192 kHz?
Thanks.
