Topic: RME adi 2 DAC FS
I am currently using lumin u1 mini. I am considering RME ADI 2 DAC FS. Can I use a USB cable to connect the 2 devices. If I want to upgrade the firmware then I have to do this only via PC.
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → RME adi 2 DAC FS
Ntsaf1...
Yes. To apply new FW to your ADI-2 DAC, You simply need to:
*Download RME Firmware to your Computer
*Extract the file
*Connect Computer to your RME via USB Connection
*Click on the extracted FUT file
(FUT=Flash Update Tool)
*Poof! Done! Takes only Seconds!
*Power the RME Off, then On for the Update to be Finalized.
Because RME never stops improving their product, since years I do this routinely it seems. This procedure (Windows) works fine.
Curt
Stu? Wha?
RME's USB input works perfectly with a variety of USB devices. My Super Vintage SBTs work superbly via USB, not to mention the RPI-4...
Bit Perfect all. Where's the question?
Curt
Ok, so the usb port performs 2 tasks: First the upgrade of firmware and second the transfer of digital signal from lumin to RME and then deciding it to analogue and send it to CXA81 amp
Stu? Wha?
Curt
Curt, oops then my mistake. Deleted my confusing post between post #2 and #3 to avoid confusion & Learned something new!
