1 (edited by alfonsoenciso 2022-05-25 22:41:48)
Topic: Apple M1 Max + Fireface UFX+ macOS Monterey driver not loading
I've been using my Fireface UFX+ for years without any issues in Windows and Mac with intel chips but now I have an issue after latest Monterey update.
Basically I can't get the driver to load no matter what.
I have tried deleting all kext-consent entries
https://forum.rme-audio.de/viewtopic.php?id=33277
and manually added the team identifier
https://forum.rme-audio.de/viewtopic.php?id=30462
but still no luck
macOS Monterey Version 12.4
Fireface UFX+:
Software version 46
  Vendor Name:    RME GmbH
  Device Name:    Fireface UFX+
  Mode:    Thunderbolt
  Device ID:    0x1
  Vendor ID:    0x129
  Device Revision:    0x1
  UID:    0x0129000000002530
  Route String:    1
  Firmware Version:    7.3
  Port (Upstream):
  Status:    Device connected
  Link Status:    0x2
  Speed:    Up to 10Gb/s x1
  Port Micro Firmware Version:    2.0.7
  Cable Firmware Version:    1.0.16
  Cable Serial Number:    C4M6202018EF798AF
Any ideas?
2 (edited by alfonsoenciso 2022-05-26 10:03:37)
Re: Apple M1 Max + Fireface UFX+ macOS Monterey driver not loading
I've always had issues finding posts related to Fireface UFX+ I think it should have it's own category.
I've learnt that its product it's under MADI/AES premium line, don't know why hmm but anyway the solution was in this post
https://forum.rme-audio.de/viewtopic.php?id=35324
I had to update the firmware first and install the thunderbolt beta drivers and it works now!
Where did you find the thunderbolt beta drivers? Are they the same as the USB 4.x drivers found in the thread you linked?
4 (edited by alfonsoenciso 2022-07-11 09:26:13)
Hi Johey,
It's in this one https://forum.rme-audio.de/viewtopic.php?id=35327
5 (edited by Minouche007 2022-09-05 14:09:25)
but still no luck
Fireface UFX+:
Software version 46
  Mode:    Thunderbolt
  Device ID:    0x1
  Vendor ID:    0x129
  Route String:    1
  Port (Upstream):
  Link Status:    0x2
Any ideas?
I have exactly the same issues with UFX Plus and M 1 (Pro/Max) Monterey 12.5.1 and I’m afraid that the next macOS versions will be not compatible at all with UFX Plus that’s why after 10 days struggling with the driver i had to send it back to the store
I challenge anyone who will tell me the opposite UFX Plus has huge issues with macOS 12.5.1 and yes RME should make a special forum for UFX Plus as i said i sent it back and back to my old UCX but now im thinking to change everything
Oh yes why i can’t post a new (own thread)  anyway?? specially when it comes to UFX Plus and macOS
I tested Ventura beta and the old Kernel Extension drivers were still working on my M1s.
But that was updating from Monterey.
Fresh install my be different, perhaps.
UFX+, FireFace 802 FS, Digiface USB
12 Mic, M1610 pro, Micstasy
MacBookPro M1
Logic Pro X
As i said the big issue under 12.5.1 and UFX Plus is that Apple removed many drivers and i think UFX Plus ist among this issue and im afraid that this will take a while in case there’s a solution for it
Before i did the update everything was fine and i think UFX Plus is the best sounding audio interface i ever used in my last 16 years on making music i wish will be a happy end for this
I'm still using the old Thunderbolt and USB drivers on 12.5.1
No need to upgrade to beta Driverkit stuff if you want to work with RME gear.
MacBookPro M1
Logic Pro X
Cigame, you are my only hope - can you share which exact version names (links if you have) to each download you are referring to here? I am on Monterey 12.5.1 M1, flying around in the dark here trying to figure out which to download, have tried a bunch of options and am seemingly coming up short.
