Topic: 2 Raydat Cards possible?
Hi, I've searched a lot but couldn't find the answer to this:
Can I cascade 2 Raydat cards? I'm running out of ins and outs...
I would go with an external device as well but then it's higher latencies as far as I'm aware...
Also, does anyone have a good recommendation for good adat converters with multiple (8 or 16) ins and/or outs? Not looking for cheap stuff like Behringer...
Thanks!
HDSPe MADI FX / Euphonix AM713 converters
13700K CPU
16GB RAM
RTX4090
Re: 2 Raydat Cards possible?
Yes, this works, the driver theoretically supports up to 6 cards.
The market for converters like that seems fairly small these days.
Thank you a lot, and I already built it in. Works fine except for the strange problem I will open a new thread for (signal from one adat source feeds into another).
Can you perhaps elaborate very briefly on why not many people want these converters? How else would I connect more than 4 or 8 sound generators? And the raydat doesn't even have analog in/out (not more than 2 anyway).
13700K CPU
16GB RAM
RTX4090
I wasn't commenting on the buyers' side, just on the fact that there seem to be relatively few simple 8-channel AD/DA converters out there these days.
5 (edited by ramses 2022-06-09 16:17:24)
https://www.thomann.de/de/digitalwandle … ilter=true
If you want not the worst, you need to consider Ferrofish, around €1000.
In this case an alternative would have been to consider an UFX II, then you have already 8 analog inputs and the 4 mic inputs can also be used for Instr or Line. Alternatively UFX+ if you want to have options to expand.
Because Ferrofish and RayDAT cost around €15xx.
With the UFX II/+ you would have had also excellent mic preamps and features like Autoset and DURec.
Additionally the advantage of USB being able to connect the recording interface to a lot of different computers.
