Topic: Babyface pro in standalone mode
Hey,
I wish to use the Babyface pro as a live mixer in standalone mode (no MAC, PC or IPAD connected). Input 1 and 2 each have a microphone connected. I have 2 active speakers for the audience. An active speaker is therefore connected to both XLR outs.
Now I notice that only input 1 can be heard from one speaker and input 2 from the other speaker. I expected to be able to hear both microphones in each speaker.
Am I doing something wrong or do I need to activate something? I can currently only solve this by first running Totalmix FX via Ipad or MAC, then disconnecting the USB and then it will work in standalone mode, as long as I don't disconnect the power to the Babyface pro.
Isn't there a way to get an identical mix from both speakers directly in standalone mode?
Thanks in advance for the suggestions
Tom
Re: Babyface pro in standalone mode
Sorry, no, standalone mixing does not come with panorama control.
OK. thanks for the quick response. One more question just to be sure:
If I first connect the babyface (CC mode) to the Ipad and then adjust the mix with the Totalmix FX app, and then remove the USB connection, do I keep the settings as long as I keep the Babyface powered? I want to be sure that I don't lose the setting during a set...
Settings should stay unchanged until the BF Pro looses power. Try it...
