Topic: USB Flash Tool Fail (TotalMix does not connect - Mac Studio)
Hi all,
can you help me with this: I just got a new Mac Studio (base model, Monterey 12.4) and I can't get my Fireface 802 to run with my DAW.
I have gone through the steps as described on the RME website (recovery mode + allow kernel extensions) and was able to install the latest USB drivers (Fireface USB 327).
Total Mix and Fireface USB settings are running and the Fireface is regognized by my DAW (Reaper) but playback/recording etc. doesn't work. Also Total Mix says "disconnected".
When I run the USB series Flash Tool and hit "update" it says: Failed with error 90000004/3 (if I run it several times this number changes while it still failes). I have reinstalled the USB drivers and the Flash Tool several times (removed all installation files before as instructed in the forum) but the result is the same. I also tried different USB cables, turned the device + mac on and off etc.
As I have read in another thread Firewire doesn't run with the Mac Studio, so buying an FW800 to Thunderbolt/USB3 adapter is also not a solution, right?
I don't really get the Class Compliant mode thing, the audio midi setup says 48kHz 8ch 32-Bit Gleitzahl but doesn't give me an option to change anything (I am obviously a rookie in this regard)
It is frustrating. Can you please help me with this?
Thank you so much in advance!
All the best,
Andreas
