1 (edited by alkhalafahmad95 2022-07-31 04:02:00)
Topic: No sound in my headphones (Help!)
Hi, i got the RME babyface pro FS.
Installed total mix fine and configurations from the web site. Windows 10 pro.
Both in total mix and rme babyface pro fs interface body i can see that the fader works fine and moving up and down when listening to something through youtube or whatever.
In my all headphones ( 3 headphones ) there is no sound at all.
Please help. It cost me a lot.
2 (edited by ramses 2022-08-01 11:02:35)
Re: No sound in my headphones (Help!)
Sounds like a routing issue, did you make yourself familiar with TM FX routing in submix mode?
https://forum.rme-audio.de/viewtopic.php?id=34394
In particular: https://www.youtube.com/watch?v=CcWClPViBm0
Each HW output has its individual routing/submix for monitoring.
1. ensure submix mode is enabled
2. select HW output for phones
3. move fader of HW inputs / SW playbacks as needed.
3 (edited by alkhalafahmad95 2022-07-31 05:41:28)
Sounds like a routing issue, did you make yourself familiar with TM FX routing in submix mode ?
Each HW output has it's individual routing/submix for monitoring.
I clicked sub mix, all tracks and PH levels are working fine in ( HW inputs and Software playback )  sorry and also HW outputs are working fine
Also i dont have (Phones) channel that comes the side with Main channel.
5 (edited by ramses 2022-08-01 10:25:05)
alkhalafahmad95 wrote:
Also, I don't have (Phones) channel that comes in the side with Main channel.
Routing example: https://www.youtube.com/watch?v=ZkxzYlBiScA
For the routing of audio, it's irrelevant whether you put the HW outputs to the TM FX control room.
But it's useful to use the “Assign” button to assign
— HW output of main monitors to “Main Out”
— HW output of phones to “Phones 1”
Then you can use control room features, like e.g., DIM etc., for your main monitors and phones.
For the routing of audio it's irrelevant whether you put the HW outputs to the TM FX control room.
But it's useful to use the "Assign" button to assign
- HW output of main monitors to "Main Out"
- HW output of phones to "Phones 1"
Then you can use control room features, like e.g. DIM etc, for your main monitors and phones.
It didn’t work, can you please do it for me through any desk app.
Yoooooooooo it worked (: !!!
But can I adjust levels of phones and monitors through the i interface directly without the use of total mix app? Except for mic level.
Sure, check the buttons on top of the Babyface, and read the manual. You select the source and control it with the dial.
