Topic: Hammerfall DSP Multiface II + Digiface USB
Hi !
I'm a new user, I'm interested in the vintage Multiface II, if I have one, may I use it by connecting with a Digiface USB?
Thanks!!
RME User Forum → FireWire & USB series → Hammerfall DSP Multiface II + Digiface USB
Hi !
Thanks!!
Basically no. The MF II does not work stand-alone, it has no memory and needs connection to the computer to be set up.
Thanks, I meant, to connect the MF II with an ADAT OUT to Digiface USB, then connect Digiface USB to my computer, in this way is it possible to use MF II?
MC wrote:Basically no. The MF II does not work stand-alone, it has no memory and needs connection to the computer to be set up.
Yes, sure, but you need a control connection to the MF II as it has no stand-alone mode where you can store the routings that you want to implement.
Search forum, many topics about clock master, clock slave(s) in such a setup.
Florian514 wrote:MC wrote:Basically no. The MF II does not work stand-alone, it has no memory and needs connection to the computer to be set up.
OK thanks so much !!!
