Topic: Fireface 400 as a stand-alone unit
Hello, I have a question on Fireface 400. I’m considering buying it and use as an stan-alone unit, mainly as an BF Pro FS ADAT extension, but ideally also as a stand-alone mixer.
1) Regardless to use as an BF ADAT extension. Do I understand correctly that from the hardware level there is no option to turn on/off phantom power, choose sample rate an clock mode? Do I have set this 3 parameters in Totalmix and save this state?
2) Regardless to use as a stand-alone mixer. I don’t get how can I route signal paths. Rotary encoder has 2 modes: channel and level. But to fully route signal we need – like in Babyface – 3 parameters: input channel, output channel and level. So is it possible to freely route signals in stan-alone mode?
