Topic: Babyface Pro and 12Mic
I typically use my 12Mic connected up to my UFX+ via MADI. I can get all 12 mic channel signals to appear in TotalMix over the first 12 MADI channels. All is good. Is it possible to use the 12Mic with a Babyface Pro and have all 12Mic channel signals in TotalMix? I know that ADAT will only handle 8 of the channels at 48K, but I wasn't sure if there was a way of routing the remaining 4 mic channels.
Thanks,
Chris
2 (edited by ramses 2022-09-09 06:19:44)
Re: Babyface Pro and 12Mic
Two more mic channels of 12Mic through its headphones output, unbalanced to BBF Pro.
Either through line inputs AN 1+2, but you could also try the universal line inputs AN3+4.
Then you could have up to 12 Mic inputs
— 8 from 12Mic through ADAT
— 2 from 12Mic through Analog 3+4 IN (check whether it works)
— 2 from BBF Pro.
Thanks very much Ramses. I’ll give it a try.
