Topic: totalmix faders unresponsive
Hello all, came back to my computer today, switched it on, only to find my faders are unresponsive. I can't move any of the input faders.
On the main fader, I can only adjust the software playback faders. If I go to a phone channel, I can move the software faders up and down, but that only affects the main level. I see a second arrow at the bottom, which I can not adjust. I am on submix mode, not free mode.
Anyone that can help? Been using my UFXII for 8 years now, never encountered anyting like it. (Mac Mini M1, but over a year already, and it worked fine until today)
Re: totalmix faders unresponsive
I think it might have something to do with the trim button. I am unable to disable the trim buttons on the tracks. They are lit on every track. I suppose this is not normal?
You've obviously enabled trim mode. Just click trim again (on the right in "show" menu)
Manual 25.5.1 "View Options"
it can also happen when you switch off the interface and on again later - TotalMix gets stuck sometimes.  try exiting TotalMix and restarting it (easiest way on Windows is to create a shortcut to it, it's stored in C:\Windows\System32\TotalMixFX.exe)
