1 (edited by georgob 2022-10-14 10:48:54)
Topic: madi multimode Singlemode converter
I need to connection to madi singlemode,  but only have multimode gear.
Would this work ?
Or how could I do it?
https://gt-netstore.de/transceiver/medi … ygQAvD_BwE
Georg
Re: madi multimode Singlemode converter
https://forum.rme-audio.de/viewtopic.php?id=36052
Thanks for that, I know the thread.
The sfp singlemode Module is hard to get, (for 12mic), would this work in 12 mic as well?
https://www.thomann.de/de/directout_ann … ule_sm.htm
I am still not perfectly in the clear if the above linked transceiver from netstore would work.
Georg
4 (edited by georgob 2022-10-19 15:14:07)
I did some testing I would like to share:
1. The above linked SM sfp does work in RMEs 12Mic.
2. Connecting a singlemode transmitter directly to a multimode Receiver works, if a 10dB optical dampening plug is inserted.
3. It also works if the plug is not inserted fully.
4. Connecting a Multimode Transmitter to a singlemode Receiver does not work.
So far my short tests.
Georg
