Topic: BabyFace Pro FS and ADAT Expansion with ADA8200
Hi All,
New RME convert here and looking for some assistance expanding my BBF with a ADA8200 via ADAT.
I've had a look around the forums here and although there seem to be people with similar issues, no resolution was found.
I'm using the two TOSLINK cables to ensure the ADA is clocked to the BBF, ADA set to slave and no issues with sync.
I miced up a kit and hooked up 7 channels of the ADA and while I'm getting signal from each mic through to Totalmix, they're only coming through on 2 ADAT channels. I was expecting 7 separate channels that I can then route to Logic Pro (MacOS).
My TotalMix window looks like this:
Any help would be greatly appreciated!
