Topic: Totalmix FX ans mac OS Ventura 13.0
After installing TotalMix FX and Fireface USB setting on my computer, I still can't open TotalMixFX on my computer. I also tried :
- the option described in the following link : https://rme-audio.de/rme-macos.html (standard installation)
- the option called "definitive solution for macOS "driver not loaded" security problems"
and it still can't open TotalmixFX. Could you please help me ?
Kind regards
Re: Totalmix FX ans mac OS Ventura 13.0
It most probably is much easier just to install version 4.06 from this forum...
https://forum.rme-audio.de/viewtopic.php?id=35957
3 (edited by Droque 2022-11-15 21:09:12)
Thank you for your answer. I installed the version 4.06 but nothing changed and I still can't open TotalMix FX in my computer (Macbook pro M1 with Mac OS Ventura 13.0). How can I solve this issue ?
Is il possible to organise à phone call since it seems to be thé easiest solution ?
Sure, just contact support. You did not mention what interface you use - maybe it is in Class Compliant mode...or Windows mode...
406 Driver on Ventura works fine with the Digiface USB here on the MacbookAir. Great !
6 (edited by Droque 2022-11-16 12:42:27)
Hi MC,
You are right, my Babyface Pro FS was still in "Class Compliant" since I used to connect it to my iPad before purchasing my new MacbookPro. So, I changed the "CC mode" to the "Windows mode" and now, TotalMix FX open automatically when I connect it to my computer.
Thank you for your help !
