1
Topic: New macOS RME USB 4.06 driver – public beta test
Here comes the next update on our macOS USB DriverKit driver, see here for former version 4.04 with some more useful information: https://forum.rme-audio.de/viewtopic.php?id=35444
Version 4.06 has several small improvements in performance and compatibility. It comes with TotalMix FX 1.77 final.
System requirements: macOS 11 and up, Intel or M processor (Apple Silicon)
Installation: Double-click on driver_mac_usbdk_406.zip to expand the archive file to the driver file Fireface USB DK 406.pkg. Installation works automatically by a double-click on the pkg (package) file. Users that tried version 4.0 will not see the Allow dialog and button anymore. All others should get that dialog, and before reboot should check that in Security & Privacy, tab General, the RME driver is allowed to load. If not unlock the settings and allow it. Then reboot computer.
Notes
A previously installed kernel extension driver, like 3.27, does not need to be uninstalled. It will be overwritten automatically. After that you could set the system security back to normal, unless any other existing kernel extensions still need reduced security.
To go back to 3.27: easiest method is to drag the Fireface USB Settings app found in the folder Applications to the trash can - only use the Finder for this action. With DriverKit this Settings dialog is 'the app', upon removal all driver files belonging to it will also be removed automatically. You will be asked for permission for the removal of the extensions. If done simply reinstall the former 3.27.
As an alternative we also made a version of the 3.27 driver available that should reliably remove the DriverKit extension during its installation, see link below. The one found on our website for download is not guaranteed to always do that.
Downloads:
https://www.rme-audio.de/downloads/driv … ac_406.zip
Former driver 3.27 with updated installer to remove DriverKit 4.0x:
https://www.rme-audio.de/downloads/driv … ac_327.zip
Any feedback is much appreciated.
Update: the zip now includes TM FX 1.78. Simply redownload 4.06 and reinstall it to have the latest state.
Re: New macOS RME USB 4.06 driver – public beta test
Installed on MacOS 12.6 with DF USB.
Install successful in one go.
After reboot per installer DF USB recognized ok
DF USB lock to ADAT/SPDIF signal ok
TM works ok
TM snapshot recalls ok
ARC USB works as usual = ok
ADI2, Digiface, ARC
one not before noted quirk: When TM mixer window is open, but another app has the focus, ARC USB Speakers B knob first brings TM to the foreground and a 2nd press hides the mixer window again.
My pref would be to make it so that when TM mixer window is open regardless of which app has the focus that the ARC USB Speakers B button hides TM mixer instead of bringing it up and a 2nd press then brings it up + puts it on the foreground in focus.
ADI2, Digiface, ARC
Your pref does not make sense to me. Using the ARC I want to check what it does and that requires TM FX to be brought into the foreground (become fully visible). Closing it seems useless and an unnecessary additional button push for the most logical action. Maybe others can chime in here how they see it. But please don't ask for an option to have it both ways.
I updated to MacOs 12.6 and now I get the audio output distortion reliably after a couple of minutes. Re-boot doesn't help anymore. Driver 4.06 doesn't change the problem. I have to go back to 3.27.
Nuendo 12.0.40, RME Madiface XT, MacMini 2018, 3.2ghz 6 core i7, 32gb ram, Monterey 12.5.
No desire to have it both ways.
ADI2, Digiface, ARC
I have a rather strange issue after I install this beta driver (I was using the stable driver before installing the 4.06 beta)
Now every time I restart my laptop, 2 of the 4 DAWs I use won't remember the audio interface I select, and upon opening the DAW, they automatically change to Macbook Pro internal speakers as the audio interface.
Logic Pro X(10.7.4) and Reaper(6.67): No issue, remember the selected audio interface upon laptop restart
Studio One (5.5) and Ableton Live(11.6): Both won't remember the audio interface I set after laptop restart, they will remember the selection as long as I don't restart the laptop.
Computer: Macbook Pro 14" M1 MAX 32 core 64GB RAM
OS: Monterey 12.6
Audio Interface: RME UFX+ via USB 3.0 connection
Never had this issue with the stable driver.
Another issue that only start to happen after updating the driver to 4.06.
If I power off and UFX+ and sleep the Macbook Pro overnight, power on the UFX+ and wake up the Macbook pro the next day.
Youtube playback on Safari video and audio will be out of sync have to quit safari and reopen in order to solve this issue.
Also never have this happen in 3.27 driver
9
Please be more clear: 'stable' driver means the former kernel driver 3.x? The new DriverKit drivers need different handling from the DAW, as showcased by Cubase which first did not want to use it at all.  Ableton and Studio One seem to need an update to handle these correctly.
Thanks MC, yes. I was using 3.27 driver before installing the 4.06 Beta
Tried v4.06 with an M1 Pro running MacOS 12.6 connected to a MADIface XT.
High-numbered input channels (193-196) now appear in their "fixed" positions, but
High-numbered playback channels (193-198) still move to channels 97-102 at sample rates > 48KHz
(at least in DigiCheck NG v0.89 beta 1).
Little Mountain Music
MacOS 13.1, MADIface XT, 4 x OctaMic XTC, M-32 DA
12
Yes, DigiCheck NG will get an update.
Hi. Thanks very much for the USB DriverKit driver. Really glad for RME's continued support.
However using this public beta, version 4.06, I must report an issue.
Kit
Macbook Air, M1, 2020, macOS 12.6.
RME Fireface UC, this 4.06 driver.
Issue Faced
The Fireface AN1&2 volume resets to 00 after being set much lower when the Macbook sleeps with no audio playback. Usually pretty deafening and alarming result occurs afterwards.
This has not occurred for the 8? years I have owned the UC running release drivers. it is most certainly this beta.
Steps:
Boot Mac, Boot Fireface, Switch on Monitors.
Totalmix and the FF USB settings launch as expected.
Totalmix is set so the Main is assigned to Main Out AN 1/2, which is hooked to my monitors. Software Playback on AN 1/2 is set to zero.
Set the volume low, so main shows -30 or whatever.
No music / audio, Macbook sleeps after x minutes.
Whilst it is asleep, Fireface resets volume to 00, visible on the front panel.
Wake Mac, go deaf when a notification triggers.
On previous drivers, I'm certain the FF UC disconnected from the mac when it slept - the red light on the front came on.
I don't believe that is the case here - the FF UC doesn't show the red light but must have a... moment... where it forgets the volume set in Totalmix.
The volume buttons on the keyboard work to control the outputs, the software fader in Totalmix works and the knob on the front of the box works too.
Is there a way to pull you a log the next time I see / hear this? It isn't every time the Macbook sleeps (that would be too easy, of course hmm )
Thank you.
14
We will check this, but I suspect the Mac's volume control to do this, not our driver. A log is not possible here.
As you didn't mention your software - are you aware of this?
https://forum.rme-audio.de/viewtopic.php?id=10662
And the volume load options in the Preferences of TM FX?
15 (edited by DominicPerry 2022-09-23 12:08:35)
I updated from 4.04 to 4.06 yesterday. Today I had a total disaster with MS Teams - Pulsing full volume distortion through the speakers.
I restarted Teams, rebooted the machine and still had the same result.
Reverted to 4.04 and all was fine.
I didn't have any problems with 4.04
I use an Aggregate Device for MS Teams (to stop Teams from altering the Mic volume). The only device in the Aggregate is the Babyface Pro fs.
I have the BF at 96KHz. The Aggregate device also runs at 96KHz.
MS Teams version is 1.5.00.22362 which is Apple Silicon native, but I notice that the Core Audio Driver (MSTeamsAudioDevice.driver) is still Intel.
I'm running Monterey 12.6
MBP M1 Max 10/32, 64GB RAM, 2TB
I do have the BF connected to a USB-A hub, but this has not caused issues in the past with 3.27 or 4.04
Firmware is v200 in both use cases.
Happy to test things.
Dominic
Thanks for getting back to me, MC, regarding the Main volume jumping whilst the Mac sleeps.
I left out the software because I didn't realise it could be specific. Understood, thanks for the link and confirming I'm not using Cubase.
This is occurring in Safari.
So to update my steps:
FFUC connected to Mac,
Reboot Mac,
Launch Safari,
Play then pause a youtube video,
Let the Mac sleep
FFUC resets Main to zero during sleep and… it has started panning L95 now too.
This has occurred three times in a row.
Reset the pan, turn down the volume, sleep = panned left and zeroed main outs.
I can confirm that the Fireface UC, when the Mac is sleeping, shows the red Host State light for about 5 seconds every minute or so.
Totalmix Preferences / Snapshots / Do Not Load: Main Volume is selected from the dropdown.
Let me know.
Thanks again!
17 (edited by royalbeatsuk 2022-09-24 22:25:54)
Would this update stop pops and clicks on M1 Monterey ?
also I have updated firmware on my 802 ,and my 2015 MacBook Pro running on High seirra shows an error when I run my 802 which I have been using for last 5 years and didn’t have an issue until I updated its firmware to run on my new mac M1 ,I’m stuck can’t use old MacBook Pro ,and M1 pro having pops and clicks running Logic Pro even on higher buffer.
Please help .
Thank you
Nick
18
19 (edited by dab1234@gmail.com 2022-09-29 17:45:35)
Cannot get the Flash Update Tool to work.  MacBook Pro Retina 15 inch late 2013.  Running Big Sur 11.6.5.  Connected to Fireface UC with USB.
I ran 4.06 driver install it said it worked.  I clicked the Allow button to authorize the loading of the driver and the button disappeared which I am assumed authorized the 4.06 driver.  It said the install worked I then tried to run the Flash Update Tool.  Which seemed to open but would not give me a window.
The 4.06 driver does not show up in the Library Extensions.  The first time I tried this and before the restart,  I ran the Security and Privacy systems preference and clicked the allow button (which seemed to work). Each time thereafter the allow button does not show up.   However I cannot get past this point and the driver still doesn't show up and the Fireface UC is not recognized.
I have now wasted 4 days on this and have made NO progress.  Please help.
I tried to load the 3.27 driver but it will not work either.
Thank you,
Dave Boyle 404.731.7747 dab1234@gmail.com
20 (edited by R3k 2022-10-03 22:02:26)
4.06 - I am experiencing some crashes of de.rme-audio.dkusb.
Bar some weirdness with Sound ID Reference software, Im not actually noticing the crashes of Totalmix or Fireface USB settings but Console is generating crash logs.
May possibly have something to do with the Sonarworks "Sound ID Reference" Software. That thing is temperamental.
System= MacOS Ventura Dev Beta 9, Mac Studio M1 Ultra, Logic Pro 10.7.4, Sonarworks Sound ID-Reference
EDIT: Fireface 802 connected via USB.
Translated Report (Full Report Below)
Process:               de.rme-audio.dkusb [436]
Path:                  /Library/SystemExtensions/*/de.rme-audio.dkusb
Identifier:            de.rme-audio.dkusb
Version:               1.0.34 (2)
Code Type:             ARM-64 (Native)
Parent Process:        launchd [1]
User ID:               270
Date/Time:             2022-09-29 14:17:17.3572 -0700
OS Version:            macOS 13.0 (22A5358e)
Report Version:        12
Anonymous UUID:        DF9863D8-824E-DC7C-AE41-7EE974EC1F20
Time Awake Since Boot: 150 seconds
System Integrity Protection: enabled
Crashed Thread:        3  Dispatch queue: DKUSBUserClient-Default
Exception Type:        EXC_BAD_ACCESS (SIGBUS)
Exception Codes:       KERN_PROTECTION_FAILURE at 0x0000000100fd92c4
Exception Codes:       0x0000000000000002, 0x0000000100fd92c4
Termination Reason:    Namespace SIGNAL, Code 10 Bus error: 10
Terminating Process:   exc handler [436]
VM Region Info: 0x100fd92c4 is not in any region.  Bytes after previous region: 611013  Bytes before following region: 1912124
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      MALLOC metadata             100f40000-100f44000    [   16K] rw-/rwx SM=ZER
--->  GAP OF 0x268000 BYTES
      VM_ALLOCATE                 1011ac000-1011b0000    [   16K] rw-/rwx SM=PRV
Thread 0:
0   libsystem_pthread.dylib                  0x1f9a24670 start_wqthread + 0
Thread 1:
0   libsystem_kernel.dylib                   0x1f996cd5c __sigsuspend_nocancel + 8
1   libdispatch.dylib                        0x1f98ac8b4 _dispatch_sigsuspend + 48
2   libdispatch.dylib                        0x1f98ac884 _dispatch_sig_thread + 56
Thread 2:
Thread 3 Crashed::  Dispatch queue: DKUSBUserClient-Default
0   de.rme-audio.dkusb                       0x100e38028 de_rme_audio_dkusb::initList2(IOUSBIsochronousFrame*) + 288
1   de.rme-audio.dkusb                       0x100e38d54 de_rme_audio_dkusb::outIsochCallback(int, bool, int) + 456
2   de.rme-audio.dkusb                       0x100e38d54 de_rme_audio_dkusb::outIsochCallback(int, bool, int) + 456
3   de.rme-audio.dkusb                       0x100e36380 de_rme_audio_dkusb::startTransfers(bool) + 1084
4   de.rme-audio.dkusb                       0x100e3b970 DKUSBUserClient::ExternalMethod(unsigned long long, IOUserClientMethodArguments*, IOUserClientMethodDispatch const*, OSObject*, void*) + 312
5   DriverKit                                0x1f9668aa4 IOUserClient::_ExternalMethod_Impl(unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*) + 188
6   DriverKit                                0x1f968b468 IOUserClient::_ExternalMethod_Invoke(IORPC, OSMetaClassBase*, int (*)(OSMetaClassBase*, unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*)) + 300
7   DriverKit                                0x1f968b250 IOUserClient::_Dispatch(IOUserClient*, IORPC) + 192
8   de.rme-audio.dkusb                       0x100e3d16c DKUSBUserClient::_Dispatch(DKUSBUserClient*, IORPC) + 264
9   de.rme-audio.dkusb                       0x100e3d058 DKUSBUserClient::Dispatch(IORPC) + 36
10  DriverKit                                0x1f9662410 invocation function for block in OSMetaClassBase::Invoke(IORPC) + 156
11  DriverKit                                0x1f9661e64 OSMetaClassBase::Invoke(IORPC) + 884
12  DriverKit                                0x1f9662c5c Server(void*, mach_msg_header_t*, mach_msg_header_t*) + 520
13  DriverKit                                0x1f966b420 uiomessage(void*) + 180
14  DriverKit                                0x1f9664694 uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int) + 380
15  libdispatch.dylib                        0x1f98b468c _dispatch_mach_msg_invoke + 472
16  libdispatch.dylib                        0x1f98a0484 _dispatch_lane_serial_drain + 380
17  libdispatch.dylib                        0x1f98b5620 _dispatch_mach_invoke + 852
18  libdispatch.dylib                        0x1f98a0484 _dispatch_lane_serial_drain + 380
19  libdispatch.dylib                        0x1f98a1130 _dispatch_lane_invoke + 436
20  libdispatch.dylib                        0x1f98a240c _dispatch_workloop_invoke + 1784
21  libdispatch.dylib                        0x1f98abf5c _dispatch_workloop_worker_thread + 652
22  libsystem_pthread.dylib                  0x1f9a1d024 _pthread_wqthread + 404
23  libsystem_pthread.dylib                  0x1f9a24678 start_wqthread + 8
Thread 3 crashed with ARM Thread State (64-bit):
    x0: 0x0000600003b14058   x1: 0x0000000104918000   x2: 0x0000000000000000   x3: 0x0000000000000000
    x4: 0x4da2b68c00000000   x5: 0x000e0c7700000004   x6: 0x0000000000000084   x7: 0x0000000000000000
    x8: 0x0000000000000484   x9: 0x00000000000000c2  x10: 0x0000000000000003  x11: 0x00000000000002fe
   x12: 0x0000000104918038  x13: 0x000000000000011f  x14: 0x0000000000000251  x15: 0x0000000000000060
   x16: 0x0000000100ea0000  x17: 0x0000000000000001  x18: 0x0000000000000000  x19: 0x0000600003b14058
   x20: 0x0000000104918000  x21: 0x0000000100fd92c4  x22: 0x0000000000000245  x23: 0x00000000000000c2
   x24: 0x0000000000000000  x25: 0x0000000104918000  x26: 0x00000000e00002c2  x27: 0x00000000000000b1
   x28: 0x0000000126e04080   fp: 0x000000016f055520   lr: 0x0000000100e38d54
    sp: 0x000000016f0554f0   pc: 0x0000000100e38028 cpsr: 0x80001000
   far: 0x0000000100fd92c4  esr: 0x92000047 (Data Abort) byte write Translation fault
Binary Images:
       0x1f9a16000 -        0x1f9a25ff3 libsystem_pthread.dylib (*) <cc4a91ff-584e-3014-913d-72c4b30c3e81> /System/DriverKit/usr/lib/system/libsystem_pthread.dylib
       0x1f9966000 -        0x1f999dff3 libsystem_kernel.dylib (*) <b5fd5edd-8579-348a-a4c7-d86da36464a1> /System/DriverKit/usr/lib/system/libsystem_kernel.dylib
       0x1f988e000 -        0x1f98d9fff libdispatch.dylib (*) <2f1bc3c9-8e64-3b3c-8024-ecb7c60dfd19> /System/DriverKit/usr/lib/system/libdispatch.dylib
       0x100e30000 -        0x100e3ffff de.rme-audio.dkusb (1.0.34) <d95cef90-ea94-3a7a-9df1-4fa2c680d317> /Library/SystemExtensions/*/de.rme-audio.dkusb
       0x1f9657000 -        0x1f969b00d DriverKit (*) <18db450b-7fa2-356d-b037-4de2c3626641> /System/DriverKit/System/Library/Frameworks/DriverKit.framework/DriverKit
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=5400K resident=0K(0%) swapped_out_or_unallocated=5400K(100%)
Writable regions: Total=549.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=549.4M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Kernel Alloc Once                   32K        1
MALLOC                           163.3M       23
MALLOC guard page                   96K        4
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                         64K        4
Stack                             2208K        5
Stack Guard                       64.0M        2
VM_ALLOCATE                         32K        2
__AUTH                              39K        8
__AUTH_CONST                       116K       19
__DATA                             168K       20
__DATA_CONST                        67K       19
__DATA_DIRTY                        22K        3
__LINKEDIT                        1888K        3
__TEXT                            3512K       21
dyld private memory                256K        1
shared memory                       32K        2
TOTAL                            619.6M      138
TOTAL, minus reserved VM space   235.6M      138
Full Report
{"app_name":"de.rme-audio.dkusb","timestamp":"2022-09-29 14:17:17.00 -0700","app_version":"1.0.34","slice_uuid":"d95cef90-ea94-3a7a-9df1-4fa2c680d317","build_version":"2","platform":10,"bundleID":"de.rme-audio.dkusb","share_with_app_devs":1,"is_first_party":1,"bug_type":"309","os_version":"macOS 13.0 (22A5358e)","roots_installed":0,"name":"de.rme-audio.dkusb","incident_id":"F260B74B-C659-4F40-B575-E81670C6761C"}
  "uptime" : 150,
  "procRole" : "Default",
  "version" : 2,
  "userID" : 270,
  "deployVersion" : 210,
  "modelCode" : "Mac13,2",
  "coalitionID" : 353,
  "osVersion" : {
    "train" : "macOS 13.0",
    "build" : "22A5358e",
    "releaseType" : "User"
  "captureTime" : "2022-09-29 14:17:17.3572 -0700",
  "incident" : "F260B74B-C659-4F40-B575-E81670C6761C",
  "pid" : 436,
  "translated" : false,
  "cpuType" : "ARM-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2022-09-29 14:14:56.5232 -0700",
  "procStartAbsTime" : 339587384,
  "procExitAbsTime" : 3719381858,
  "procName" : "de.rme-audio.dkusb",
  "procPath" : "\/Library\/SystemExtensions\/*\/de.rme-audio.dkusb",
  "bundleInfo" : {"CFBundleShortVersionString":"1.0.34","CFBundleVersion":"2","CFBundleIdentifier":"de.rme-audio.dkusb"},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "de.rme-audio.dkusb",
  "crashReporterKey" : "DF9863D8-824E-DC7C-AE41-7EE974EC1F20",
  "sip" : "enabled",
  "vmRegionInfo" : "0x100fd92c4 is not in any region.  Bytes after previous region: 611013  Bytes before following region: 1912124\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      MALLOC metadata             100f40000-100f44000    [   16K] rw-\/rwx SM=ZER  \n--->  GAP OF 0x268000 BYTES\n      VM_ALLOCATE                 1011ac000-1011b0000    [   16K] rw-\/rwx SM=PRV  ",
  "exception" : {"codes":"0x0000000000000002, 0x0000000100fd92c4","rawCodes":[2,4311585476],"type":"EXC_BAD_ACCESS","signal":"SIGBUS","subtype":"KERN_PROTECTION_FAILURE at 0x0000000100fd92c4"},
  "termination" : {"flags":0,"code":10,"namespace":"SIGNAL","indicator":"Bus error: 10","byProc":"exc handler","byPid":436},
  "vmregioninfo" : "0x100fd92c4 is not in any region.  Bytes after previous region: 611013  Bytes before following region: 1912124\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      MALLOC metadata             100f40000-100f44000    [   16K] rw-\/rwx SM=ZER  \n--->  GAP OF 0x268000 BYTES\n      VM_ALLOCATE                 1011ac000-1011b0000    [   16K] rw-\/rwx SM=PRV  ",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 3,
  "threads" : [{"id":5114,"frames":[{"imageOffset":58992,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":0}]},{"id":5115,"frames":[{"imageOffset":27996,"symbol":"__sigsuspend_nocancel","symbolLocation":8,"imageIndex":1},{"imageOffset":125108,"symbol":"_dispatch_sigsuspend","symbolLocation":48,"imageIndex":2},{"imageOffset":125060,"symbol":"_dispatch_sig_thread","symbolLocation":56,"imageIndex":2}]},{"id":8636,"frames":[{"imageOffset":58992,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":0}]},{"triggered":true,"id":10113,"threadState":{"x":[{"value":105553178214488},{"value":4371611648},{"value":0},{"value":0},{"value":5594234399559254016},{"value":3954354914590724},{"value":132},{"value":0},{"value":1156},{"value":194},{"value":3},{"value":766},{"value":4371611704},{"value":287},{"value":593},{"value":96},{"value":4310302720},{"value":1},{"value":0},{"value":105553178214488},{"value":4371611648},{"value":4311585476},{"value":581},{"value":194},{"value":0},{"value":4371611648},{"value":3758097090},{"value":177},{"value":4947198080}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4309880148},"cpsr":{"value":2147487744},"fp":{"value":6157587744},"sp":{"value":6157587696},"esr":{"value":2449473607,"description":"(Data Abort) byte write Translation fault"},"pc":{"value":4309876776,"matchesCrashFrame":1},"far":{"value":4311585476}},"queue":"DKUSBUserClient-Default","frames":[{"imageOffset":32808,"symbol":"de_rme_audio_dkusb::initList2(IOUSBIsochronousFrame*)","symbolLocation":288,"imageIndex":3},{"imageOffset":36180,"symbol":"de_rme_audio_dkusb::outIsochCallback(int, bool, int)","symbolLocation":456,"imageIndex":3},{"imageOffset":36180,"symbol":"de_rme_audio_dkusb::outIsochCallback(int, bool, int)","symbolLocation":456,"imageIndex":3},{"imageOffset":25472,"symbol":"de_rme_audio_dkusb::startTransfers(bool)","symbolLocation":1084,"imageIndex":3},{"imageOffset":47472,"symbol":"DKUSBUserClient::ExternalMethod(unsigned long long, IOUserClientMethodArguments*, IOUserClientMethodDispatch const*, OSObject*, void*)","symbolLocation":312,"imageIndex":3},{"imageOffset":72356,"symbol":"IOUserClient::_ExternalMethod_Impl(unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*)","symbolLocation":188,"imageIndex":4},{"imageOffset":214120,"symbol":"IOUserClient::_ExternalMethod_Invoke(IORPC, OSMetaClassBase*, int (*)(OSMetaClassBase*, unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*))","symbolLocation":300,"imageIndex":4},{"imageOffset":213584,"symbol":"IOUserClient::_Dispatch(IOUserClient*, IORPC)","symbolLocation":192,"imageIndex":4},{"imageOffset":53612,"symbol":"DKUSBUserClient::_Dispatch(DKUSBUserClient*, IORPC)","symbolLocation":264,"imageIndex":3},{"imageOffset":53336,"symbol":"DKUSBUserClient::Dispatch(IORPC)","symbolLocation":36,"imageIndex":3},{"imageOffset":46096,"symbol":"invocation function for block in OSMetaClassBase::Invoke(IORPC)","symbolLocation":156,"imageIndex":4},{"imageOffset":44644,"symbol":"OSMetaClassBase::Invoke(IORPC)","symbolLocation":884,"imageIndex":4},{"imageOffset":48220,"symbol":"Server(void*, mach_msg_header_t*, mach_msg_header_t*)","symbolLocation":520,"imageIndex":4},{"imageOffset":82976,"symbol":"uiomessage(void*)","symbolLocation":180,"imageIndex":4},{"imageOffset":54932,"symbol":"uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int)","symbolLocation":380,"imageIndex":4},{"imageOffset":157324,"symbol":"_dispatch_mach_msg_invoke","symbolLocation":472,"imageIndex":2},{"imageOffset":74884,"symbol":"_dispatch_lane_serial_drain","symbolLocation":380,"imageIndex":2},{"imageOffset":161312,"symbol":"_dispatch_mach_invoke","symbolLocation":852,"imageIndex":2},{"imageOffset":74884,"symbol":"_dispatch_lane_serial_drain","symbolLocation":380,"imageIndex":2},{"imageOffset":78128,"symbol":"_dispatch_lane_invoke","symbolLocation":436,"imageIndex":2},{"imageOffset":82956,"symbol":"_dispatch_workloop_invoke","symbolLocation":1784,"imageIndex":2},{"imageOffset":122716,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":652,"imageIndex":2},{"imageOffset":28708,"symbol":"_pthread_wqthread","symbolLocation":404,"imageIndex":0},{"imageOffset":59000,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":0}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8483069952,
    "size" : 65524,
    "uuid" : "cc4a91ff-584e-3014-913d-72c4b30c3e81",
    "path" : "\/System\/DriverKit\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8482349056,
    "size" : 229364,
    "uuid" : "b5fd5edd-8579-348a-a4c7-d86da36464a1",
    "path" : "\/System\/DriverKit\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8481464320,
    "size" : 311296,
    "uuid" : "2f1bc3c9-8e64-3b3c-8024-ecb7c60dfd19",
    "path" : "\/System\/DriverKit\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "arm64",
    "base" : 4309843968,
    "CFBundleShortVersionString" : "1.0.34",
    "CFBundleIdentifier" : "de.rme-audio.dkusb",
    "size" : 65536,
    "uuid" : "d95cef90-ea94-3a7a-9df1-4fa2c680d317",
    "path" : "\/Library\/SystemExtensions\/*\/de.rme-audio.dkusb",
    "name" : "de.rme-audio.dkusb",
    "CFBundleVersion" : "2"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8479141888,
    "size" : 278542,
    "uuid" : "18db450b-7fa2-356d-b037-4de2c3626641",
    "path" : "\/System\/DriverKit\/System\/Library\/Frameworks\/DriverKit.framework\/DriverKit",
    "name" : "DriverKit"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
  "sharedCache" : {
  "base" : 8478900224,
  "size" : 73400320,
  "uuid" : "4b7c8ae5-c27c-373d-8cc9-05123587d8d9"
  "vmSummary" : "ReadOnly portion of Libraries: Total=5400K resident=0K(0%) swapped_out_or_unallocated=5400K(100%)\nWritable regions: Total=549.4M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=549.4M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nKernel Alloc Once                   32K        1 \nMALLOC                           163.3M       23 \nMALLOC guard page                   96K        4 \nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nSTACK GUARD                         64K        4 \nStack                             2208K        5 \nStack Guard                       64.0M        2 \nVM_ALLOCATE                         32K        2 \n__AUTH                              39K        8 \n__AUTH_CONST                       116K       19 \n__DATA                             168K       20 \n__DATA_CONST                        67K       19 \n__DATA_DIRTY                        22K        3 \n__LINKEDIT                        1888K        3 \n__TEXT                            3512K       21 \ndyld private memory                256K        1 \nshared memory                       32K        2 \n===========                     =======  ======= \nTOTAL                            619.6M      138 \nTOTAL, minus reserved VM space   235.6M      138 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "DKUSBUserClient-Default"
Process:               de.rme-audio.dkusb [410]
Version:               1.0.34 (2)
User ID:               270
Date/Time:             2022-09-29 14:27:37.2853 -0700
Report Version:        12
Time Awake Since Boot: 260 seconds
Exception Codes:       KERN_PROTECTION_FAILURE at 0x0000000102c309bc
Exception Codes:       0x0000000000000002, 0x0000000102c309bc
Terminating Process:   exc handler [410]
VM Region Info: 0x102c309bc is not in any region.  Bytes after previous region: 543165  Bytes before following region: 63977028
      __LINKEDIT                  102b58000-102bac000    [  336K] r--/r-- SM=COW  /usr/lib/dyld
--->  GAP OF 0x3d88000 BYTES
      VM_ALLOCATE                 106934000-10693c000    [   32K] rw-/rwx SM=PRV
Thread 0:
0   libsystem_kernel.dylib                   0x1f8080d5c __sigsuspend_nocancel + 8
1   libdispatch.dylib                        0x1f7fc08b4 _dispatch_sigsuspend + 48
2   libdispatch.dylib                        0x1f7fc0884 _dispatch_sig_thread + 56
Thread 1:
0   libsystem_pthread.dylib                  0x1f8138670 start_wqthread + 0
Thread 2::  Dispatch queue: de_rme_audio_dkusb-Default
0   de.rme-audio.dkusb                       0x10298c028 de_rme_audio_dkusb::initList2(IOUSBIsochronousFrame*) + 288
1   de.rme-audio.dkusb                       0x10298cd54 de_rme_audio_dkusb::outIsochCallback(int, bool, int) + 456
2   de.rme-audio.dkusb                       0x10298cd54 de_rme_audio_dkusb::outIsochCallback(int, bool, int) + 456
3   de.rme-audio.dkusb                       0x1029918d4 de_rme_audio_dkusb::IsochIOReadComplete_Invoke(IORPC, OSMetaClassBase*, void (*)(OSMetaClassBase*, OSAction*, int)) + 112
4   de.rme-audio.dkusb                       0x1029917c0 de_rme_audio_dkusb::_Dispatch(de_rme_audio_dkusb*, IORPC) + 1356
5   de.rme-audio.dkusb                       0x102991268 de_rme_audio_dkusb::Dispatch(IORPC) + 36
6   DriverKit                                0x1f7d76410 invocation function for block in OSMetaClassBase::Invoke(IORPC) + 156
7   DriverKit                                0x1f7d75e64 OSMetaClassBase::Invoke(IORPC) + 884
8   DriverKit                                0x1f7d76c5c Server(void*, mach_msg_header_t*, mach_msg_header_t*) + 520
9   DriverKit                                0x1f7d7f420 uiomessage(void*) + 180
10  DriverKit                                0x1f7d78694 uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int) + 380
11  libdispatch.dylib                        0x1f7fc868c _dispatch_mach_msg_invoke + 472
12  libdispatch.dylib                        0x1f7fb4484 _dispatch_lane_serial_drain + 380
13  libdispatch.dylib                        0x1f7fc9620 _dispatch_mach_invoke + 852
14  libdispatch.dylib                        0x1f7fb4484 _dispatch_lane_serial_drain + 380
15  libdispatch.dylib                        0x1f7fb5130 _dispatch_lane_invoke + 436
16  libdispatch.dylib                        0x1f7fb640c _dispatch_workloop_invoke + 1784
17  libdispatch.dylib                        0x1f7fbff5c _dispatch_workloop_worker_thread + 652
18  libsystem_pthread.dylib                  0x1f8131024 _pthread_wqthread + 404
19  libsystem_pthread.dylib                  0x1f8138678 start_wqthread + 8
3   de.rme-audio.dkusb                       0x10298a380 de_rme_audio_dkusb::startTransfers(bool) + 1084
4   de.rme-audio.dkusb                       0x10298f970 DKUSBUserClient::ExternalMethod(unsigned long long, IOUserClientMethodArguments*, IOUserClientMethodDispatch const*, OSObject*, void*) + 312
5   DriverKit                                0x1f7d7caa4 IOUserClient::_ExternalMethod_Impl(unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*) + 188
6   DriverKit                                0x1f7d9f468 IOUserClient::_ExternalMethod_Invoke(IORPC, OSMetaClassBase*, int (*)(OSMetaClassBase*, unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*)) + 300
7   DriverKit                                0x1f7d9f250 IOUserClient::_Dispatch(IOUserClient*, IORPC) + 192
8   de.rme-audio.dkusb                       0x10299116c DKUSBUserClient::_Dispatch(DKUSBUserClient*, IORPC) + 264
9   de.rme-audio.dkusb                       0x102991058 DKUSBUserClient::Dispatch(IORPC) + 36
10  DriverKit                                0x1f7d76410 invocation function for block in OSMetaClassBase::Invoke(IORPC) + 156
11  DriverKit                                0x1f7d75e64 OSMetaClassBase::Invoke(IORPC) + 884
12  DriverKit                                0x1f7d76c5c Server(void*, mach_msg_header_t*, mach_msg_header_t*) + 520
13  DriverKit                                0x1f7d7f420 uiomessage(void*) + 180
14  DriverKit                                0x1f7d78694 uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int) + 380
15  libdispatch.dylib                        0x1f7fc868c _dispatch_mach_msg_invoke + 472
16  libdispatch.dylib                        0x1f7fb4484 _dispatch_lane_serial_drain + 380
17  libdispatch.dylib                        0x1f7fc9620 _dispatch_mach_invoke + 852
18  libdispatch.dylib                        0x1f7fb4484 _dispatch_lane_serial_drain + 380
19  libdispatch.dylib                        0x1f7fb5130 _dispatch_lane_invoke + 436
20  libdispatch.dylib                        0x1f7fb640c _dispatch_workloop_invoke + 1784
21  libdispatch.dylib                        0x1f7fbff5c _dispatch_workloop_worker_thread + 652
22  libsystem_pthread.dylib                  0x1f8131024 _pthread_wqthread + 404
23  libsystem_pthread.dylib                  0x1f8138678 start_wqthread + 8
    x0: 0x000060000306c058   x1: 0x0000000103d38000   x2: 0x0000000000000000   x3: 0x0000000000000000
    x4: 0x4da2b68c00000000   x5: 0x000f3c1300000004   x6: 0x0000000000000084   x7: 0x0000000000000000
    x8: 0x0000000000000484   x9: 0x00000000000000c2  x10: 0x0000000000000002  x11: 0x0000000000001a0e
   x12: 0x0000000103d38020  x13: 0x0000000000000683  x14: 0x0000000000000dc3  x15: 0x0000000000000342
   x16: 0x00000001029f4000  x17: 0x0000000000000001  x18: 0x0000000000000000  x19: 0x000060000306c058
   x20: 0x0000000103d38000  x21: 0x0000000102c309bc  x22: 0x0000000000000db7  x23: 0x00000000000000c2
   x24: 0x0000000000000000  x25: 0x0000000103d38000  x26: 0x00000000e00002c2  x27: 0x0000000000000036
   x28: 0x000000012ce043a0   fp: 0x000000016d6a5520   lr: 0x000000010298cd54
    sp: 0x000000016d6a54f0   pc: 0x000000010298c028 cpsr: 0x80001000
   far: 0x0000000102c309bc  esr: 0x92000047 (Data Abort) byte write Translation fault
Binary Images:
       0x1f807a000 -        0x1f80b1ff3 libsystem_kernel.dylib (*) <b5fd5edd-8579-348a-a4c7-d86da36464a1> /System/DriverKit/usr/lib/system/libsystem_kernel.dylib
       0x1f7fa2000 -        0x1f7fedfff libdispatch.dylib (*) <2f1bc3c9-8e64-3b3c-8024-ecb7c60dfd19> /System/DriverKit/usr/lib/system/libdispatch.dylib
       0x1f812a000 -        0x1f8139ff3 libsystem_pthread.dylib (*) <cc4a91ff-584e-3014-913d-72c4b30c3e81> /System/DriverKit/usr/lib/system/libsystem_pthread.dylib
       0x102984000 -        0x102993fff de.rme-audio.dkusb (1.0.34) <d95cef90-ea94-3a7a-9df1-4fa2c680d317> /Library/SystemExtensions/*/de.rme-audio.dkusb
       0x1f7d6b000 -        0x1f7daf00d DriverKit (*) <18db450b-7fa2-356d-b037-4de2c3626641> /System/DriverKit/System/Library/Frameworks/DriverKit.framework/DriverKit
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
Full Report
{"app_name":"de.rme-audio.dkusb","timestamp":"2022-09-29 14:27:37.00 -0700","app_version":"1.0.34","slice_uuid":"d95cef90-ea94-3a7a-9df1-4fa2c680d317","build_version":"2","platform":10,"bundleID":"de.rme-audio.dkusb","share_with_app_devs":1,"is_first_party":1,"bug_type":"309","os_version":"macOS 13.0 (22A5358e)","roots_installed":0,"name":"de.rme-audio.dkusb","incident_id":"657ED7FA-7E0C-4FFC-B12D-C3DE7BFBAD62"}
  "uptime" : 260,
  "version" : 2,
  "userID" : 270,
  "coalitionID" : 347,
  "osVersion" : {
  "captureTime" : "2022-09-29 14:27:37.2853 -0700",
  "incident" : "657ED7FA-7E0C-4FFC-B12D-C3DE7BFBAD62",
  "pid" : 410,
  "bug_type" : "309",
  "procLaunch" : "2022-09-29 14:23:29.2215 -0700",
  "procStartAbsTime" : 318332516,
  "procExitAbsTime" : 6271759785,
  "parentPid" : 1,
  "sip" : "enabled",
  "vmRegionInfo" : "0x102c309bc is not in any region.  Bytes after previous region: 543165  Bytes before following region: 63977028\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      __LINKEDIT                  102b58000-102bac000    [  336K] r--\/r-- SM=COW  \/usr\/lib\/dyld\n--->  GAP OF 0x3d88000 BYTES\n      VM_ALLOCATE                 106934000-10693c000    [   32K] rw-\/rwx SM=PRV  ",
  "exception" : {"codes":"0x0000000000000002, 0x0000000102c309bc","rawCodes":[2,4341303740],"type":"EXC_BAD_ACCESS","signal":"SIGBUS","subtype":"KERN_PROTECTION_FAILURE at 0x0000000102c309bc"},
  "termination" : {"flags":0,"code":10,"namespace":"SIGNAL","indicator":"Bus error: 10","byProc":"exc handler","byPid":410},
  "vmregioninfo" : "0x102c309bc is not in any region.  Bytes after previous region: 543165  Bytes before following region: 63977028\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      __LINKEDIT                  102b58000-102bac000    [  336K] r--\/r-- SM=COW  \/usr\/lib\/dyld\n--->  GAP OF 0x3d88000 BYTES\n      VM_ALLOCATE                 106934000-10693c000    [   32K] rw-\/rwx SM=PRV  ",
  "threads" : [{"id":4990,"frames":[{"imageOffset":27996,"symbol":"__sigsuspend_nocancel","symbolLocation":8,"imageIndex":0},{"imageOffset":125108,"symbol":"_dispatch_sigsuspend","symbolLocation":48,"imageIndex":1},{"imageOffset":125060,"symbol":"_dispatch_sig_thread","symbolLocation":56,"imageIndex":1}]},{"id":12132,"frames":[{"imageOffset":58992,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":2}]},{"id":12579,"queue":"de_rme_audio_dkusb-Default","frames":[{"imageOffset":32808,"symbol":"de_rme_audio_dkusb::initList2(IOUSBIsochronousFrame*)","symbolLocation":288,"imageIndex":3},{"imageOffset":36180,"symbol":"de_rme_audio_dkusb::outIsochCallback(int, bool, int)","symbolLocation":456,"imageIndex":3},{"imageOffset":36180,"symbol":"de_rme_audio_dkusb::outIsochCallback(int, bool, int)","symbolLocation":456,"imageIndex":3},{"imageOffset":55508,"symbol":"de_rme_audio_dkusb::IsochIOReadComplete_Invoke(IORPC, OSMetaClassBase*, void (*)(OSMetaClassBase*, OSAction*, int))","symbolLocation":112,"imageIndex":3},{"imageOffset":55232,"symbol":"de_rme_audio_dkusb::_Dispatch(de_rme_audio_dkusb*, IORPC)","symbolLocation":1356,"imageIndex":3},{"imageOffset":53864,"symbol":"de_rme_audio_dkusb::Dispatch(IORPC)","symbolLocation":36,"imageIndex":3},{"imageOffset":46096,"symbol":"invocation function for block in OSMetaClassBase::Invoke(IORPC)","symbolLocation":156,"imageIndex":4},{"imageOffset":44644,"symbol":"OSMetaClassBase::Invoke(IORPC)","symbolLocation":884,"imageIndex":4},{"imageOffset":48220,"symbol":"Server(void*, mach_msg_header_t*, mach_msg_header_t*)","symbolLocation":520,"imageIndex":4},{"imageOffset":82976,"symbol":"uiomessage(void*)","symbolLocation":180,"imageIndex":4},{"imageOffset":54932,"symbol":"uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int)","symbolLocation":380,"imageIndex":4},{"imageOffset":157324,"symbol":"_dispatch_mach_msg_invoke","symbolLocation":472,"imageIndex":1},{"imageOffset":74884,"symbol":"_dispatch_lane_serial_drain","symbolLocation":380,"imageIndex":1},{"imageOffset":161312,"symbol":"_dispatch_mach_invoke","symbolLocation":852,"imageIndex":1},{"imageOffset":74884,"symbol":"_dispatch_lane_serial_drain","symbolLocation":380,"imageIndex":1},{"imageOffset":78128,"symbol":"_dispatch_lane_invoke","symbolLocation":436,"imageIndex":1},{"imageOffset":82956,"symbol":"_dispatch_workloop_invoke","symbolLocation":1784,"imageIndex":1},{"imageOffset":122716,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":652,"imageIndex":1},{"imageOffset":28708,"symbol":"_pthread_wqthread","symbolLocation":404,"imageIndex":2},{"imageOffset":59000,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":2}]},{"triggered":true,"id":14277,"threadState":{"x":[{"value":105553167040600},{"value":4359159808},{"value":0},{"value":0},{"value":5594234399559254016},{"value":4288176952705028},{"value":132},{"value":0},{"value":1156},{"value":194},{"value":2},{"value":6670},{"value":4359159840},{"value":1667},{"value":3523},{"value":834},{"value":4338958336},{"value":1},{"value":0},{"value":105553167040600},{"value":4359159808},{"value":4341303740},{"value":3511},{"value":194},{"value":0},{"value":4359159808},{"value":3758097090},{"value":54},{"value":5047862176}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4338535764},"cpsr":{"value":2147487744},"fp":{"value":6130652448},"sp":{"value":6130652400},"esr":{"value":2449473607,"description":"(Data Abort) byte write Translation fault"},"pc":{"value":4338532392,"matchesCrashFrame":1},"far":{"value":4341303740}},"queue":"DKUSBUserClient-Default","frames":[{"imageOffset":32808,"symbol":"de_rme_audio_dkusb::initList2(IOUSBIsochronousFrame*)","symbolLocation":288,"imageIndex":3},{"imageOffset":36180,"symbol":"de_rme_audio_dkusb::outIsochCallback(int, bool, int)","symbolLocation":456,"imageIndex":3},{"imageOffset":36180,"symbol":"de_rme_audio_dkusb::outIsochCallback(int, bool, int)","symbolLocation":456,"imageIndex":3},{"imageOffset":25472,"symbol":"de_rme_audio_dkusb::startTransfers(bool)","symbolLocation":1084,"imageIndex":3},{"imageOffset":47472,"symbol":"DKUSBUserClient::ExternalMethod(unsigned long long, IOUserClientMethodArguments*, IOUserClientMethodDispatch const*, OSObject*, void*)","symbolLocation":312,"imageIndex":3},{"imageOffset":72356,"symbol":"IOUserClient::_ExternalMethod_Impl(unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*)","symbolLocation":188,"imageIndex":4},{"imageOffset":214120,"symbol":"IOUserClient::_ExternalMethod_Invoke(IORPC, OSMetaClassBase*, int (*)(OSMetaClassBase*, unsigned long long, unsigned long long const*, unsigned int, OSData*, IOMemoryDescriptor*, unsigned long long*, unsigned int*, unsigned long long, OSData**, IOMemoryDescriptor*, OSAction*))","symbolLocation":300,"imageIndex":4},{"imageOffset":213584,"symbol":"IOUserClient::_Dispatch(IOUserClient*, IORPC)","symbolLocation":192,"imageIndex":4},{"imageOffset":53612,"symbol":"DKUSBUserClient::_Dispatch(DKUSBUserClient*, IORPC)","symbolLocation":264,"imageIndex":3},{"imageOffset":53336,"symbol":"DKUSBUserClient::Dispatch(IORPC)","symbolLocation":36,"imageIndex":3},{"imageOffset":46096,"symbol":"invocation function for block in OSMetaClassBase::Invoke(IORPC)","symbolLocation":156,"imageIndex":4},{"imageOffset":44644,"symbol":"OSMetaClassBase::Invoke(IORPC)","symbolLocation":884,"imageIndex":4},{"imageOffset":48220,"symbol":"Server(void*, mach_msg_header_t*, mach_msg_header_t*)","symbolLocation":520,"imageIndex":4},{"imageOffset":82976,"symbol":"uiomessage(void*)","symbolLocation":180,"imageIndex":4},{"imageOffset":54932,"symbol":"uiomachchannel(void*, dispatch_mach_reason_t, dispatch_mach_msg_s*, int)","symbolLocation":380,"imageIndex":4},{"imageOffset":157324,"symbol":"_dispatch_mach_msg_invoke","symbolLocation":472,"imageIndex":1},{"imageOffset":74884,"symbol":"_dispatch_lane_serial_drain","symbolLocation":380,"imageIndex":1},{"imageOffset":161312,"symbol":"_dispatch_mach_invoke","symbolLocation":852,"imageIndex":1},{"imageOffset":74884,"symbol":"_dispatch_lane_serial_drain","symbolLocation":380,"imageIndex":1},{"imageOffset":78128,"symbol":"_dispatch_lane_invoke","symbolLocation":436,"imageIndex":1},{"imageOffset":82956,"symbol":"_dispatch_workloop_invoke","symbolLocation":1784,"imageIndex":1},{"imageOffset":122716,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":652,"imageIndex":1},{"imageOffset":28708,"symbol":"_pthread_wqthread","symbolLocation":404,"imageIndex":2},{"imageOffset":59000,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":2}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8456216576,
    "size" : 229364,
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8455331840,
    "size" : 311296,
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8456937472,
    "size" : 65524,
    "source" : "P",
    "arch" : "arm64",
    "base" : 4338499584,
    "size" : 65536,
    "source" : "P",
    "arch" : "arm64e",
    "base" : 8453009408,
    "size" : 278542,
    "size" : 0,
    "source" : "A",
    "base" : 0,
  "sharedCache" : {
  "base" : 8452767744,
  "size" : 73400320,
  "legacyInfo" : {
Process:               RMEUsbAsp [362]
Path:                  /Library/Audio/Plug-Ins/HAL/RMEUsbAsp.driver/Contents/MacOS/RMEUsbAsp
Identifier:            de.rme-audio.UsbAsp
Version:               1.0.10 (1)
User ID:               202
Date/Time:             2022-09-23 22:37:50.7182 -0700
OS Version:            macOS 13.0 (22A5352e)
Report Version:        12
Time Awake Since Boot: 42000 seconds
Crashed Thread:        2  Dispatch queue: com.apple.NSXPCConnection.user.anonymous.198
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x000000000000003c
Exception Codes:       0x0000000000000001, 0x000000000000003c
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [362]
VM Region Info: 0x3c is not in any region.  Bytes before following region: 105553518919620
      UNUSED SPACE AT START
      MALLOC_NANO (reserved)   600018000000-600020000000 [128.0M] rw-/rwx SM=NUL  ...(unallocated)
Thread 0::  Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib                   0x1b0626dd0 mach_msg2_trap + 8
1   libsystem_kernel.dylib                   0x1b06388b8 mach_msg2_internal + 80
2   libsystem_kernel.dylib                   0x1b062f618 mach_msg_overwrite + 540
3   libsystem_kernel.dylib                   0x1b062714c mach_msg + 24
4   CoreFoundation                           0x1b074606c __CFRunLoopServiceMachPort + 160
5   CoreFoundation                           0x1b0744958 __CFRunLoopRun + 1232
6   CoreFoundation                           0x1b0743d34 CFRunLoopRunSpecific + 612
7   CoreAudio                                0x1b2821b20 AudioServerPlugInMain + 2984
8   dyld                                     0x1b033be50 start + 2544
Thread 1:: caulk.messenger.shared:17
0   libsystem_kernel.dylib                   0x1b0626d4c semaphore_wait_trap + 8
1   caulk                                    0x1b9ac8cfc caulk::mach::semaphore::wait_or_error() + 28
2   caulk                                    0x1b9aab634 caulk::concurrent::details::worker_thread::run() + 56
3   caulk                                    0x1b9aab278 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 96
4   libsystem_pthread.dylib                  0x1b066606c _pthread_start + 148
5   libsystem_pthread.dylib                  0x1b0660e2c thread_start + 8
Thread 2 Crashed::  Dispatch queue: com.apple.NSXPCConnection.user.anonymous.198
0   RMEUsbAsp                                0x100172aa0 0x100160000 + 76448
1   RMEUsbAsp                                0x100172a9c 0x100160000 + 76444
2   RMEUsbAsp                                0x1001729a8 0x100160000 + 76200
3   RMEUsbAsp                                0x1001661bc 0x100160000 + 25020
4   CoreAudio                                0x1b2ad1994 -[Core_Audio_Driver start_io:client_id:reply:] + 92
5   CoreFoundation                           0x1b0728294 __invoking___ + 148
6   CoreFoundation                           0x1b072810c -[NSInvocation invoke] + 428
7   Foundation                               0x1b169977c __NSXPCCONNECTION_IS_CALLING_OUT_TO_EXPORTED_OBJECT__ + 16
8   Foundation                               0x1b1ce249c -[NSXPCConnection _decodeAndInvokeMessageWithEvent:reply:flags:] + 1204
9   Foundation                               0x1b1ce3e34 message_handler_message + 88
10  Foundation                               0x1b1ce38a0 message_handler + 152
11  libxpc.dylib                             0x1b03d43a8 _xpc_connection_call_event_handler + 152
12  libxpc.dylib                             0x1b03d2da8 _xpc_connection_mach_event + 1380
13  libdispatch.dylib                        0x1b04df5c4 _dispatch_client_callout4 + 20
14  libdispatch.dylib                        0x1b04fbfe8 _dispatch_mach_msg_invoke + 468
15  libdispatch.dylib                        0x1b04e6a94 _dispatch_lane_serial_drain + 376
16  libdispatch.dylib                        0x1b04fcd04 _dispatch_mach_invoke + 448
17  libdispatch.dylib                        0x1b04e6a94 _dispatch_lane_serial_drain + 376
18  libdispatch.dylib                        0x1b04e773c _dispatch_lane_invoke + 436
19  libdispatch.dylib                        0x1b04f234c _dispatch_workloop_worker_thread + 652
20  libsystem_pthread.dylib                  0x1b0662100 _pthread_wqthread + 288
21  libsystem_pthread.dylib                  0x1b0660e20 start_wqthread + 8
Thread 3::  Dispatch queue: SA_PlugIn
0   Foundation                               0x1b160aa68 +[NSAutoreleasePool allocWithZone:] + 56
1   libobjc.A.dylib                          0x1b0324a58 objc_opt_new + 112
2   libobjc.A.dylib                          0x1b0324a58 objc_opt_new + 112
3   Foundation                               0x1b160a0e0 -[NSXPCConnection _sendInvocation:orArguments:count:methodSignature:selector:withProxy:] + 1128
4   CoreFoundation                           0x1b07268f8 ___forwarding___ + 1016
5   CoreFoundation                           0x1b0726440 _CF_forwarding_prep_0 + 96
6   CoreAudio                                0x1b2ccc14c -[Core_Audio_Driver_Host_Proxy driver_properties_changed:properties_data:] + 264
7   CoreAudio                                0x1b2ccc8bc Host_Interface::properties_changed(AudioServerPlugInHostInterface const*, unsigned int, unsigned int, AudioObjectPropertyAddress const*) + 84
8   RMEUsbAsp                                0x100164dbc 0x100160000 + 19900
9   IOKit                                    0x1b3826b94 IODispatchCalloutFromCFMessage + 332
10  IOKit                                    0x1b3826a38 _IODispatchCalloutWithDispatch + 44
11  libdispatch.dylib                        0x1b04fda64 dispatch_mig_server + 424
12  libdispatch.dylib                        0x1b04df504 _dispatch_client_callout + 20
13  libdispatch.dylib                        0x1b04e2994 _dispatch_continuation_pop + 504
14  libdispatch.dylib                        0x1b04f5fa0 _dispatch_source_invoke + 1588
16  libdispatch.dylib                        0x1b04e7708 _dispatch_lane_invoke + 384
17  libdispatch.dylib                        0x1b04f234c _dispatch_workloop_worker_thread + 652
18  libsystem_pthread.dylib                  0x1b0662100 _pthread_wqthread + 288
19  libsystem_pthread.dylib                  0x1b0660e20 start_wqthread + 8
Thread 4:
0   libsystem_pthread.dylib                  0x1b0660e18 start_wqthread + 0
Thread 5:
Thread 2 crashed with ARM Thread State (64-bit):
    x0: 0x0000000120008510   x1: 0xffffffffffffffff   x2: 0xfffffffffffffff0   x3: 0x00000001200087f0
    x4: 0x0000000120008580   x5: 0x0000000000000000   x6: 0x0000000000000000   x7: 0x0000000000000000
    x8: 0x0000000000000000   x9: 0x0000000000000000  x10: 0x0007a0000007a002  x11: 0x00000000000380dd
   x12: 0x0000000000000001  x13: 0x00079f0000079f02  x14: 0x00079f000007a002  x15: 0x000000020c308d38
   x16: 0x00000001b0693c00  x17: 0x0000000210bbb5d8  x18: 0x0000000000000000  x19: 0x0000000120008200
   x20: 0x0000000120008510  x21: 0x00000000000186a0  x22: 0x0000000000000000  x23: 0x0000000125704530
   x24: 0x0000000000000001  x25: 0x0000000000000000  x26: 0x0000600003d98000  x27: 0x0000000000000001
   x28: 0x00006000017b80c0   fp: 0x000000016fe3e000   lr: 0x0000000100172a9c
    sp: 0x000000016fe3dfe0   pc: 0x0000000100172aa0 cpsr: 0x80001000
   far: 0x000000000000003c  esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
       0x1b0626000 -        0x1b065efeb libsystem_kernel.dylib (*) <b54eb397-ff4e-3415-8536-d98a24ab7d35> /usr/lib/system/libsystem_kernel.dylib
       0x1b06c4000 -        0x1b0b9bfff com.apple.CoreFoundation (6.9) <eef8b379-1217-304b-b53d-70cd1e1f32c6> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
       0x1b275b000 -        0x1b2e39fff com.apple.audio.CoreAudio (5.0) <aaa40915-1553-3733-b022-1c80ec1d5f62> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
       0x1b0336000 -        0x1b03c02a3 dyld (*) <a806cc48-a704-37f7-923b-8158a3d68c05> /usr/lib/dyld
       0x1b9aa9000 -        0x1b9ad2fff com.apple.audio.caulk (1.0) <7f8d0ac8-1137-3be8-bbc4-e80b97b6130a> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
       0x1b065f000 -        0x1b066bffb libsystem_pthread.dylib (*) <93540939-bf1b-3a4a-bb32-923eb7326b45> /usr/lib/system/libsystem_pthread.dylib
       0x100160000 -        0x100177fff de.rme-audio.UsbAsp (1.0.10) <b963f244-a511-3d3f-a14d-0bbec51238c8> /Library/Audio/Plug-Ins/HAL/RMEUsbAsp.driver/Contents/MacOS/RMEUsbAsp
       0x1b15ee000 -        0x1b2026fff com.apple.Foundation (6.9) <13f36666-dc15-3bdf-8c77-3cdc37d43315> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
       0x1b03c6000 -        0x1b0408fff libxpc.dylib (*) <0b22640a-ff62-34a5-ad64-449bc85aeab0> /usr/lib/system/libxpc.dylib
       0x1b04db000 -        0x1b0522fff libdispatch.dylib (*) <e9ee5856-9547-3a0c-9a33-610c2892ebe9> /usr/lib/system/libdispatch.dylib
       0x1b02f0000 -        0x1b0335d9f libobjc.A.dylib (*) <0aaada28-b470-3943-87d0-344cc9d765a4> /usr/lib/libobjc.A.dylib
       0x1b3821000 -        0x1b38fcfff com.apple.framework.IOKit (2.0.2) <f17f3fa6-7ce8-3091-8f57-d512aaf94ba6> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=919.3M resident=0K(0%) swapped_out_or_unallocated=919.3M(100%)
Writable regions: Total=960.8M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=960.8M(100%)
                                VIRTUAL   REGION
Activity Tracing                   256K        1
MALLOC                           324.3M       51
MALLOC_MEDIUM (reserved)         240.0M        2         reserved VM address space (unallocated)
STACK GUARD                       56.1M        6
Stack                             11.3M       28
VM_ALLOCATE                        368K        1
__AUTH                             444K       93
__AUTH_CONST                      7952K      223
__DATA                            2123K      207
__DATA_CONST                      9247K      224
__DATA_DIRTY                       446K       85
__FONT_DATA                        2352        1
__LINKEDIT                       761.4M        2
__OBJC_CONST                       619K       75
__OBJC_RO                         65.0M        1
__OBJC_RW                         1977K        1
__TEXT                           157.9M      233
mapped file                         64K        1
shared memory                      688K       23
TOTAL                              2.0G     1265
TOTAL, minus reserved VM space     1.4G     1265
Full Report
{"app_name":"RMEUsbAsp","timestamp":"2022-09-23 22:37:52.00 -0700","app_version":"1.0.10","slice_uuid":"b963f244-a511-3d3f-a14d-0bbec51238c8","build_version":"1","platform":1,"bundleID":"de.rme-audio.UsbAsp","share_with_app_devs":1,"is_first_party":1,"bug_type":"309","os_version":"macOS 13.0 (22A5352e)","roots_installed":0,"name":"RMEUsbAsp","incident_id":"B635A12F-C436-48F2-B606-30D1B89475A5"}
  "uptime" : 42000,
  "version" : 2,
  "userID" : 202,
  "coalitionID" : 281,
  "osVersion" : {
    "build" : "22A5352e",
  "captureTime" : "2022-09-23 22:37:50.7182 -0700",
  "incident" : "B635A12F-C436-48F2-B606-30D1B89475A5",
  "pid" : 362,
  "bug_type" : "309",
  "procLaunch" : "2022-09-23 10:45:18.4425 -0700",
  "procStartAbsTime" : 279825515,
  "procExitAbsTime" : 1026333702459,
  "procName" : "RMEUsbAsp",
  "procPath" : "\/Library\/Audio\/Plug-Ins\/HAL\/RMEUsbAsp.driver\/Contents\/MacOS\/RMEUsbAsp",
  "bundleInfo" : {"CFBundleShortVersionString":"1.0.10","CFBundleVersion":"1","CFBundleIdentifier":"de.rme-audio.UsbAsp"},
  "parentPid" : 1,
  "coalitionName" : "asp.de.rme-audio.UsbAsp",
  "sip" : "enabled",
  "vmRegionInfo" : "0x3c is not in any region.  Bytes before following region: 105553518919620\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      MALLOC_NANO (reserved)   600018000000-600020000000 [128.0M] rw-\/rwx SM=NUL  ...(unallocated)",
  "exception" : {"codes":"0x0000000000000001, 0x000000000000003c","rawCodes":[1,60],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x000000000000003c"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":362},
  "vmregioninfo" : "0x3c is not in any region.  Bytes before following region: 105553518919620\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      MALLOC_NANO (reserved)   600018000000-600020000000 [128.0M] rw-\/rwx SM=NUL  ...(unallocated)",
  "faultingThread" : 2,
  "threads" : [{"id":4532,"queue":"com.apple.main-thread","frames":[{"imageOffset":3536,"symbol":"mach_msg2_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":75960,"symbol":"mach_msg2_internal","symbolLocation":80,"imageIndex":0},{"imageOffset":38424,"symbol":"mach_msg_overwrite","symbolLocation":540,"imageIndex":0},{"imageOffset":4428,"symbol":"mach_msg","symbolLocation":24,"imageIndex":0},{"imageOffset":532588,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":160,"imageIndex":1},{"imageOffset":526680,"symbol":"__CFRunLoopRun","symbolLocation":1232,"imageIndex":1},{"imageOffset":523572,"symbol":"CFRunLoopRunSpecific","symbolLocation":612,"imageIndex":1},{"imageOffset":813856,"symbol":"AudioServerPlugInMain","symbolLocation":2984,"imageIndex":2},{"imageOffset":24144,"symbol":"start","symbolLocation":2544,"imageIndex":3}]},{"id":4562,"name":"caulk.messenger.shared:17","frames":[{"imageOffset":3404,"symbol":"semaphore_wait_trap","symbolLocation":8,"imageIndex":0},{"imageOffset":130300,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":28,"imageIndex":4},{"imageOffset":9780,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":56,"imageIndex":4},{"imageOffset":8824,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":96,"imageIndex":4},{"imageOffset":28780,"symbol":"_pthread_start","symbolLocation":148,"imageIndex":5},{"imageOffset":7724,"symbol":"thread_start","symbolLocation":8,"imageIndex":5}]},{"triggered":true,"id":229597,"threadState":{"x":[{"value":4831872272},{"value":18446744073709551615},{"value":18446744073709551600},{"value":4831873008},{"value":4831872384},{"value":0},{"value":0},{"value":0},{"value":0},{"value":0},{"value":2146246697918466},{"value":229597},{"value":1},{"value":2145147186290434},{"value":2145147186290690},{"value":8794443064,"symbolLocation":0,"symbol":"OBJC_CLASS_$_Core_Audio_Driver"},{"value":7254653952,"symbolLocation":0,"symbol":"_platform_memset"},{"value":8870671832},{"value":0},{"value":4831871488},{"value":4831872272},{"value":100000},{"value":0},{"value":4923082032},{"value":1},{"value":0},{"value":105553180852224},{"value":1},{"value":105553141137600}],"flavor":"ARM_THREAD_STATE64","lr":{"value":4296485532},"cpsr":{"value":2147487744},"fp":{"value":6172172288},"sp":{"value":6172172256},"esr":{"value":2449473542,"description":"(Data Abort) byte read Translation fault"},"pc":{"value":4296485536,"matchesCrashFrame":1},"far":{"value":60}},"queue":"com.apple.NSXPCConnection.user.anonymous.198","frames":[{"imageOffset":76448,"imageIndex":6},{"imageOffset":76444,"imageIndex":6},{"imageOffset":76200,"imageIndex":6},{"imageOffset":25020,"imageIndex":6},{"imageOffset":3631508,"symbol":"-[Core_Audio_Driver start_io:client_id:reply:]","symbolLocation":92,"imageIndex":2},{"imageOffset":410260,"symbol":"__invoking___","symbolLocation":148,"imageIndex":1},{"imageOffset":409868,"symbol":"-[NSInvocation invoke]","symbolLocation":428,"imageIndex":1},{"imageOffset":702332,"symbol":"__NSXPCCONNECTION_IS_CALLING_OUT_TO_EXPORTED_OBJECT__","symbolLocation":16,"imageIndex":7},{"imageOffset":7292060,"symbol":"-[NSXPCConnection _decodeAndInvokeMessageWithEvent:reply:flags:]","symbolLocation":1204,"imageIndex":7},{"imageOffset":7298612,"symbol":"message_handler_message","symbolLocation":88,"imageIndex":7},{"imageOffset":7297184,"symbol":"message_handler","symbolLocation":152,"imageIndex":7},{"imageOffset":58280,"symbol":"_xpc_connection_call_event_handler","symbolLocation":152,"imageIndex":8},{"imageOffset":52648,"symbol":"_xpc_connection_mach_event","symbolLocation":1380,"imageIndex":8},{"imageOffset":17860,"symbol":"_dispatch_client_callout4","symbolLocation":20,"imageIndex":9},{"imageOffset":135144,"symbol":"_dispatch_mach_msg_invoke","symbolLocation":468,"imageIndex":9},{"imageOffset":47764,"symbol":"_dispatch_lane_serial_drain","symbolLocation":376,"imageIndex":9},{"imageOffset":138500,"symbol":"_dispatch_mach_invoke","symbolLocation":448,"imageIndex":9},{"imageOffset":47764,"symbol":"_dispatch_lane_serial_drain","symbolLocation":376,"imageIndex":9},{"imageOffset":51004,"symbol":"_dispatch_lane_invoke","symbolLocation":436,"imageIndex":9},{"imageOffset":95052,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":652,"imageIndex":9},{"imageOffset":12544,"symbol":"_pthread_wqthread","symbolLocation":288,"imageIndex":5},{"imageOffset":7712,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":5}]},{"id":229857,"queue":"SA_PlugIn","frames":[{"imageOffset":117352,"symbol":"+[NSAutoreleasePool allocWithZone:]","symbolLocation":56,"imageIndex":7},{"imageOffset":215640,"symbol":"objc_opt_new","symbolLocation":112,"imageIndex":10},{"imageOffset":215640,"symbol":"objc_opt_new","symbolLocation":112,"imageIndex":10},{"imageOffset":114912,"symbol":"-[NSXPCConnection _sendInvocation:orArguments:count:methodSignature:selector:withProxy:]","symbolLocation":1128,"imageIndex":7},{"imageOffset":403704,"symbol":"___forwarding___","symbolLocation":1016,"imageIndex":1},{"imageOffset":402496,"symbol":"_CF_forwarding_prep_0","symbolLocation":96,"imageIndex":1},{"imageOffset":5706060,"symbol":"-[Core_Audio_Driver_Host_Proxy driver_properties_changed:properties_data:]","symbolLocation":264,"imageIndex":2},{"imageOffset":5707964,"symbol":"Host_Interface::properties_changed(AudioServerPlugInHostInterface const*, unsigned int, unsigned int, AudioObjectPropertyAddress const*)","symbolLocation":84,"imageIndex":2},{"imageOffset":19900,"imageIndex":6},{"imageOffset":23444,"symbol":"IODispatchCalloutFromCFMessage","symbolLocation":332,"imageIndex":11},{"imageOffset":23096,"symbol":"_IODispatchCalloutWithDispatch","symbolLocation":44,"imageIndex":11},{"imageOffset":141924,"symbol":"dispatch_mig_server","symbolLocation":424,"imageIndex":9},{"imageOffset":17668,"symbol":"_dispatch_client_callout","symbolLocation":20,"imageIndex":9},{"imageOffset":31124,"symbol":"_dispatch_continuation_pop","symbolLocation":504,"imageIndex":9},{"imageOffset":110496,"symbol":"_dispatch_source_invoke","symbolLocation":1588,"imageIndex":9},{"imageOffset":47764,"symbol":"_dispatch_lane_serial_drain","symbolLocation":376,"imageIndex":9},{"imageOffset":50952,"symbol":"_dispatch_lane_invoke","symbolLocation":384,"imageIndex":9},{"imageOffset":95052,"symbol":"_dispatch_workloop_worker_thread","symbolLocation":652,"imageIndex":9},{"imageOffset":12544,"symbol":"_pthread_wqthread","symbolLocation":288,"imageIndex":5},{"imageOffset":7712,"symbol":"start_wqthread","symbolLocation":8,"imageIndex":5}]},{"id":230245,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":243857,"frames":[{"imageOffset":7704,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7254204416,
    "size" : 233452,
    "uuid" : "b54eb397-ff4e-3415-8536-d98a24ab7d35",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7254851584,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5079040,
    "uuid" : "eef8b379-1217-304b-b53d-70cd1e1f32c6",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1951"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7289024512,
    "CFBundleShortVersionString" : "5.0",
    "CFBundleIdentifier" : "com.apple.audio.CoreAudio",
    "size" : 7204864,
    "uuid" : "aaa40915-1553-3733-b022-1c80ec1d5f62",
    "path" : "\/System\/Library\/Frameworks\/CoreAudio.framework\/Versions\/A\/CoreAudio",
    "name" : "CoreAudio",
    "CFBundleVersion" : "5.0"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7251124224,
    "size" : 565924,
    "uuid" : "a806cc48-a704-37f7-923b-8158a3d68c05",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7409930240,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 172032,
    "uuid" : "7f8d0ac8-1137-3be8-bbc4-e80b97b6130a",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7254437888,
    "size" : 53244,
    "uuid" : "93540939-bf1b-3a4a-bb32-923eb7326b45",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "source" : "P",
    "arch" : "arm64",
    "base" : 4296409088,
    "CFBundleShortVersionString" : "1.0.10",
    "CFBundleIdentifier" : "de.rme-audio.UsbAsp",
    "size" : 98304,
    "uuid" : "b963f244-a511-3d3f-a14d-0bbec51238c8",
    "path" : "\/Library\/Audio\/Plug-Ins\/HAL\/RMEUsbAsp.driver\/Contents\/MacOS\/RMEUsbAsp",
    "name" : "RMEUsbAsp",
    "CFBundleVersion" : "1"
    "source" : "P",
    "arch" : "arm64e",
    "base" : 7270752256,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 10719232,
    "uuid" : "13f36666-dc15-3bdf-8c77-3cdc37d43315",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
21 (edited by stromkraft 2022-09-30 17:01:01)
Question: I updated from macOS 11 with 4.04b to macOS 12 without reinstalling the driver. Did this procedure mean I was still running the macOS 11 version driver also in 12? Did my later installation of the 4.06 post-update change this driver version, i e from 11 to 12? Or is this kind of thing dynamically handled?
For whatever reason all small issues I had with my RME Babyface and the beta in macOS 11 are gone in 12.
RME Babyface v226 | 4.07 | MacBook Pro 13" 2020 | 16gb/1tb
22 (edited by tetmin 2022-10-01 00:29:40)
Re: New macOS RME USB 4.06 driver – public beta test
This doesn't work. Fireface USB Settings app can't launch - it dies immediately after trying to launch it & the UI does not appear. Doesn't matter if USB device is connected or not.
On M2 Macbook Air - MacOS 12.6
23
Your interface?
After the last Big Sur 11.7 update I lost my UFX with 3.27 driver again. So I gave the latest 4.06 (with TM 1.78) another try.
The system becomes very sluggish every now and then. The problem seems to be with TotalMix, which sometimes uses up to 100% cpu time. The mouse moves very erratic (stays at one point, then jumps to the next, etc), and mouse clicks are not registered or only after several seconds.
Quiting TM immediately makes the system responsive again. I looked in /var/log/system.log but could not find any clues.
This is on a late 2014 iMac 27" retina, 4 GHz Quad core i7, 32 GB memory.
Ben
UFX, iMac 27" late 2014, quad i7, 32 GB ram, 1TB SSD, OSX 11.7, Logic 10.7.4, Final Cut 10.6.5
25 (edited by Raboon 2022-10-05 15:32:06)
Thanks for the updated TotalMix. Installed and testing.
Main Out is still jumping upward on sleep. Thankfully, not to 00.
Set Main Out to - infinity. Full muted.
Sleep.
Main Out jumps to -59 on the Totalmix software interface, -58 on the front of the FFUC.
Thanks again.
Edit: 05/10
FFUC main out just jumped from a non-mute value to 00 & L93 after sleep again.
So, mute jumps to -58
any other volume jumps to 00 and pans.
26 (edited by stromkraft 2022-10-04 00:36:18)
I just re-ran my quick CPU test in native Ableton Live 11 with 120 tracks of three note chords playing "Grand Piano" with a buffer of 512 samples on the original Babyface. Original M1.
3.27 in macOS 11: 120 tracks before crackling and CPU overload indication (original values)
4.06beta in macOS 12: 80 tracks before crackling and CPU overload indication
That's a 25% loss! Is this to be expected with the new user space drivers? I'll have to reinstall 3.27 to see how much of this is macOS 12. What do you think? Can performance get back to what 3.27 pulls off or is a loss inevitable? How can we help you?
Now you know why I'm running 1.21 Thunderbolt driver. It's just not worth it to switch to these newer ones unless you want more problems and a cut in track count. I'm awaiting a new Mac Pro 2019 because of all this angst over software and drivers not working properly on the new machines. Love my MBP 16 but so many things half working, if you want to make music on a machine that just works, don't beta test this crap.
This beta driver is not crap in any shape for form, despite those results. It's a beta and I knew what that might entail.
What can I say? I'm a natural born tester. I test things also on my free time, unpaid and do my bit so that others can get working stuff. When I'm working people pay me good money for the same thing. Sosumi.
28
Another embarrassing post of yours. This thread is about USB not Thunderbolt. And for Thunderbolt we just published a completely reworked version that looks very promising, and is definitely not crap.
Hi MC, where one can download the new published Thunderbolt driver? is that compatible with UFX+ and Apple Silicon M1Max computer?
30
https://forum.rme-audio.de/viewtopic.php?id=36046
Thanks MC. off-topic. Couldn't help but noticed the UFX+ is removed from the list
A refresh is coming?
https://i.imgur.com/iSUioUH.png
https://forum.rme-audio.de/viewtopic.ph … 64#p192364
https://forum.rme-audio.de/viewtopic.ph … 77#p192377
BR Ramses - UFX III, 12Mic, XTC, ADI-2 Pro FS R BE, RayDAT, X10SRi-F, E5-1680v4, Win11Pro22H2, Cub12
Dominic
Just had the same problem with 4.04. Have reverted to 3.27 but I have no idea if it's the driver or MS Teams, as the BF Pro fs works in other applications - but MS Teams also works with my other interfaces (Built in sound and Avid Carbon), meaning there is no common thread.
Dominic
Hey yall I was having some issues w/ 4.06 on m a MPB M1 Pro (glitches/dropouts on simple playback from browser or ableton 48hz). I was using a Caldigit TS3 and then the update thunderbolt 4 version of the product. Both had the same issues. Just downgraded to 3.27 and it seems to be stable so far.
35 (edited by DominicPerry 2022-10-13 12:11:19)
UPDATE:
I rolled back and I've just had the same problem with 3.27 (I used the installer that removed the 4.04 beta) so it has nothing to do with the RME drivers. I don't know what is going on, but I guess it's MS Teams specific, or a problem with my Mac or a hardware issue. Not a driver issue anyway.
Dominic
Dominic
Dominic
Quick update: since this post and the downgrade to 3.27, my system has been running stable again. (Probably until the next Big Sur upgrade. hmm )
37 (edited by Raboon 2022-10-18 18:25:49)
Fresh news - I installed the driver included here, 4.06 and then installed the one with the updated TotalMix. I've flagged the issue I'm seeing about the Main Out volume jumping and panning unexpectedly on sleep, which is still occurring.
I note that the first post states "don't worry about the old Driver, it'll be overwritten"
However I just received the pop up notification in MacOS about a Legacy System Extension from RME being installed.
That's unexpected, right?
Quick update - Found the kext in the StagedExtensions folder and it takes a terminal command to delete.
Unfortunately, deleting the spare kext hasn't solved the issue I see.
38 (edited by mattrixx 2022-10-21 08:42:29)
H all. I've been observing some strange issues (using 4.06 beta driver). However, I am not certain it is the driver.
If I am playing audio in Pro Tools Ultimate (2022.9) or Logic 10.7.3 and I open a Safari page and scroll a lot,  the audio coming from UFXII will sometimes intermittently drop out of glitch.
Or if I am working in Pro Tools and command-tab over to a Quicktime video, play it...stop it and then come back to Pro Tools and hit play, the audio will go all weird, until I toggle a setting in the Playback settings window, such as "Aux I/O" or "Optimise and low buffer settings"..... basically anything that will reset the audio driver.
So any of the problems I was reporting on this 4.06 beta, are more than likely an issue with the state of the current OS (12.6.1 here). Something is interrupting the audio streams.
This is with a Mac Studio Ultra.
[edit]
I have reverted back to the v3.27 Driver today and it's been working flawlessly again.
Matt McKenzie-Smith (UFXII, UFX, Babyface) MacStudioUltra OS13.2.1
DominicPerry wrote:
UPDATE:
Dominic
DominicPerry wrote:
DominicPerry wrote:
I updated from 4.04 to 4.06 yesterday. Today I had a total disaster with MS Teams - Pulsing full volume distortion through the speakers.
I restarted Teams, rebooted the machine and still had the same result.
Reverted to 4.04 and all was fine.
I didn't have any problems with 4.04
I use an Aggregate Device for MS Teams (to stop Teams from altering the Mic volume). The only device in the Aggregate is the Babyface Pro fs.
I have the BF at 96KHz. The Aggregate device also runs at 96KHz.
MS Teams version is 1.5.00.22362 which is Apple Silicon native, but I notice that the Core Audio Driver (MSTeamsAudioDevice.driver) is still Intel.
I'm running Monterey 12.6
MBP M1 Max 10/32, 64GB RAM, 2TB
I do have the BF connected to a USB-A hub, but this has not caused issues in the past with 3.27 or 4.04
Firmware is v200 in both use cases.
Happy to test things.
Dominic
Dominic
I've had nothing but trouble getting Teams to recognise my original babyface, unlike with Zoom that works fine. It does work occasionally. As all other software seems to work fine, also with 4.06, I just use my internal audio for Teams.
40 (edited by rjan 2022-10-22 13:57:19)
It looks like Teams audio driver is Intel based, it's not native M1. That could explain erratic behaviour. See https://techcommunity.microsoft.com/t5/ … -p/3589463 and read comments.
41 (edited by bog 2022-11-07 08:52:58)
Running the 4.06 beta driver on 13.0, and previously 12.0.
I have one issue only, where the sound control (up/down) slider no longer functions and controls the actual sound (same with keyboard shortcuts).
It's like there's a disconnect between the driver and macOS after prolonged use. Rebooting fixes this, until it eventually 'disconnects', and then volume control no longer works (it does via total mix though). Not sure if this is caused by my machine going to sleep, but wasn't this behaviour has only begun since moving from a non-M1 Mac Mini to M1.
Yes, I had this problem too with 4.04 and 4.06, on Monterey. Tends to get fixed by changing the volume with the wheel on the BF Pro fs, suddenly the keyboard shortcuts work again.
Dominic
This turns out to be a specific problem with Teams on M1 machines when other people in the meeting are sharing Powerpoint presentations in Live Mode. It's quite widely reported. A very weird bug.
It's not an RME problem, it's a Teams problem. The odd thing is that it didn't happen on the Intel binaries of Teams, only on the later Apple Silicon native builds.
I managed to royally hose my entire Office install by removing all of Teams, re-installing the earlier version and trying to stop Microsoft from updating. Depite my best efforts, Teams still updated all on its own and I wrecked all my Office licensing and authentication.
Anyway, the point is that it's not an RME driver issue, and certainly nothing to do with the beta either.
Dominic
44
Hope this gets fixed soon, as I really don't want to bend over and crawl under the desk to access the Fireface UC's knob big_smile
45 (edited by fieldstu 2022-11-15 02:05:22)
I noticed Wavelab does not like the v4.06beta driver. In v3.28 everything works perfect while in v4.06beta the audio does not even start. Something with the driver check by Wavelab I guess. (Digiface USB)
ADI2, Digiface, ARC
46
You might need to use an Aggregate Device. See note on Cubase/Nuendo here:
https://forum.rme-audio.de/viewtopic.ph … 69#p188269
This has been fixed in the latest Cubase/Nuendo updates, that's why we no longer mention it.
Hey guys, my Mac (ventura) detects fireface in class compliant mode. But when CC mode is off, the driver 4.06 is NOT working. I've allowed those drivers to not be blocked, but wit comes with a sample rate of 32000 HZ, meaning the Mac is not even detecting the hardware, flash tool is also not working so I can't even update the hardware. Can anyone help?
hi - Does anyone know if updating the firmware on a UFX to 361 in order to use this new driver will mean it still works ok on an older computer (intel trashcan) which is still using the 327 driver? thank you!
49
Yes it does.
Working flawlessly on Ventura 13.1 under Ableton Live 11, Audio Hijack 4, and Reaper 6.
