Topic: ASIO vs WASAPI
I have a Babyface PRO FS and record using SONAR. I have an XLR cable from my guitar amp out, going in to AN1. I see the signal hitting hitting the interface, I can hear it through my DAW speakers.
When I set the driver mode to WASAPI (Shared) my DAW doesn't see the signal. regardless of which input I select on the audio channel. If I switch to ASIO, i get a signal.
If I plug my guitar in to AN3 with a 1/4" cable, WASAPI works fine.
Am I losing anything by using ASIO, and if so, what should I look for the get WASAPI working on AN1?
