Topic: UFX II: gain changes for input 'mic 9' only change RIGHT channel?
I just setup a Fireface UFX II and I'm learning TotalMix FX. For my first recording I'm feeding a (Eurorack synthesizer) signal into Mic/input 9. I've got a TS cable running from the Eurorack into Mic/input 9.
In the TotalMix FX hardware input for this track for this input, the input level is set to "Instrument". That is, as I understand it, it has a 8.0db gain right off the bat. Pan is set to 0. The track is set to MONO (it's a mono cable going into it, as it's a TS cable).
If I pull the slider for that input all the way down in the 'hardware input' panel, that is to -∞, I still get a strong signal showing up from my input in the 'green led' display (the one that indicates levels). The blue level indicator in the window is hovers around -7.1 with the slider all the way down.
Also, the sound only comes out of the LEFT headphone side. As I raise the slider for the input up, the sound volume increases only on the RIGHT headphone side, starting from 0 (silent).
(In the 'software playback' panel, Pan is set to 0 for the headphones channel, and is set to STEREO. In the 'control room' panel, the 'phones 1' track has Pan set to 0 and is also set to 'stereo'.)
Why is there always sound (signal) coming out of the LEFT side no matter how far down I pull the slider (is this because of the 8.0 gain for instruments?)
And importantly, why does the slider in the 'mic/line 9' window only control the RIGHT side, and the LEFT side doesn't change in volume?
A friend of mine with the UFX II is stumped, as am I. Any info much appreciated!
