Topic: ADI-2 Pro mini XLR Balanced Out
i now have audeze headphones with 4 pin mini xlr connector. What kind of cables do I need to connect these balanced to the ADI-2 Pro?
I have not found any mini XLR to TRS cables on the internet and I am not very good at soldering.
Re: ADI-2 Pro mini XLR Balanced Out
I don't know of a standard adapter for this case. The balanced connection with two 6.3 TSR plugs is too exotic.
Maybe https://audioverse.de/ will make a customized one-off production.
The pinout on the RME side is described in the manual, chapter 33.7.
Ich kenne keinen serienmässigen Adapter für diesen Fall. dazu ist der symmetrische Anschluss mit zwei 6,3 TSR Steckern zu exotisch.
Vielleicht mach ja https://audioverse.de/ eine kundenspezifisch Einzelanfertigung.
Die Belegung auf Seiten RME ist in der Bedienungsanleitung, im Kapitel 33.7 Steckerbelegungen beschrieben.
Ralf
(ADI-2 Pro FS with Dell XPS13 and Dynaudio Focus 600 XD or Focal Clear — and a lot of Jazz)
3 (edited by KaiS 2023-01-21 22:13:56)
Due to ADI-2 Pro’s special double-TRS configuration for balanced ‘phones, there’s no readily available cable.
Go to a Pro-Audio / musicians store and let them do the soldering.
Show them manual page 44 for the pinout.
You can start with a standard-AUDEZE TRS-to-MiniXLR cable of your choice, let them replace the single TRS with two TRS.
Balanced vs Single-Ended with AUDEZE:
I don’t here any difference with my AUDEZE LCD-4 or LCD-2r2.
Power-wise I can stay on Single-Ended LowPower, and still need only ca. -20 dB Volume.
does that mean that I need separate 4 pin xlr to TRS cables for left and right?
One cable is soldered at the end only with pin 1/2 and the the other one only with pin 3/4?
Or should the two cables be soldered identically?
5 (edited by KaiS 2023-01-22 00:51:30)
The (full size) 4pin XLR in manual page 44 is not the AUDEZE pinout of course, can be ignored.
The relevant part for your case is the double-TRS, on the ADI-2 Pro’s side.
The pin-out for the LCD mini-XLR connectors (those that go into the headphones themselves) on the LCD series cables, to double-TRS balanced is as follows:
miniXLR 1 and 4: (+) —> TRS Tip
miniXLR 2 and 3: (-) —> TRS Ring
TRS Sleeve = not connected
Left and right are the same.
Thanks! I think I will try to make a cable myself. as a positive side effect I also learn to solder smile
Three thumbs up!
Get an adjustable temperature controlled soldering station for more fun.
Better a good used Weller than a cheap new Chinese.
This is one of the classic, analog controlled ones that will serve you a lifetime:
https://www.pkelektronik.com/media/catalog/product/0/0/0053230699.jpg
Agreed, one advantage of Weller: you get spare tips even after decades, but the old WS81 Set is now very expensive, around 300 €. That's all right if you use it 8 hours 5 days a week. The newer WE1010  (70 W instead of 80 W) is good enough for soldering a  manageable quantity of connectors and the price in the internet is only about 160€.
For soldering mini XLR an additional tip, e.g. ET P, would be helpful (about 6€).
Ralf
9
And I use one for 7 € from AliExpress, comes with 5 tips, direct 230 V connection, quick heating, temperature setting in the handle with mini LCD. Works well...
Can you give a link - always nice to save.
I bought one of these just before Xmas for rewiring the studio and building a tube guitar amp from scratch. It works great and is far better than the cheapy Chinese thing it replaced.
https://musicwall.app/hermetech
12
https://www.aliexpress.com/item/1005004569629568.html?
Sorry, the page you requested can not be found sad
Ralf
14
Regionally blocked then. Do a search on AliExpress for '80W Electric Soldering Iron Kit Set Digital Temperature Adjustable Welding Tool Solder Tin With Iron Tips Repair Tools'...there are hundreds of sellers for this stuff...
