Topic: reinitialiser
Bonjour
Savez vous comment reinitialiser le rme adi2 dac fs
LINN AKURATE DS, LINN UNIDISC SC,AMPLIS MCINTOSH C300 et MC7106 + RME
Re: reinitialiser
Manual ch 7 "Returning to Factory State"
Re: reinitialiser
Thanks I managed to reset but it didn't solve my problem
for some time (with or without AutoRevel), I have the sound that becomes bad I am forced to lower the volume (I go from 20db to 30 db on the RME) and the left and right baregraphs at the bottom of the screen show that I am at 0 (max permanently)
I am looking for the cause because before the sound was perfect
Re: reinitialiser
The same title from my PC's HDD connected to the RME via the USB input works normally
My problem comes from the COAX link?
Re: reinitialiser
What's the signal source? Is the ADI set to sync to SPDIF?
Re: reinitialiser
Digital output from my LINN AKRATE DS streamer
7
Re: reinitialiser
When the sound is bad check the ADI's Status Overview display for errors on receiving the SPDIF signal.
Re: reinitialiser
It seems that the problem comes from the streamer
9 (edited by KaiS 2023-02-01 19:03:58)
Re: reinitialiser
Replace the USB cable, nothing fancy needed, but no lomger than 2-3m.
10 (edited by john34 2023-02-08 10:25:39)
Re: reinitialiser
As I understand the OP has connected the streamer via coax spdif.
I would check if the digital volume on the linn is below 100%.
He could also check if the testfiles for different sample rates pass.
