Topic: reinitialiser
Bonjour
Savez vous comment reinitialiser le rme adi2 dac fs
RME User Forum → ADI-2 & 2/4 Pro series, ADI-2 DAC series → reinitialiser
Bonjour
Manual ch 7 "Returning to Factory State"
Thanks I managed to reset but it didn't solve my problem
for some time (with or without AutoRevel), I have the sound that becomes bad I am forced to lower the volume (I go from 20db to 30 db on the RME) and the left and right baregraphs at the bottom of the screen show that I am at 0 (max permanently)
I am looking for the cause because before the sound was perfect
The same title from my PC's HDD connected to the RME via the USB input works normally
My problem comes from the COAX link?
What's the signal source? Is the ADI set to sync to SPDIF?
Digital output from my LINN AKRATE DS streamer
When the sound is bad check the ADI's Status Overview display for errors on receiving the SPDIF signal.
It seems that the problem comes from the streamer
Replace the USB cable, nothing fancy needed, but no lomger than 2-3m.
As I understand the OP has connected the streamer via coax spdif.
I would check if the digital volume on the linn is below 100%.
He could also check if the testfiles for different sample rates pass.
