vinyllover wrote:I‘d like to hook up my KGSSHV electrostatic headphone amp via XLR and optionally switch to my speaker system (Hypex NCore mono blocks).
Can I switch between those two on the RME. What would I connect to which output?
• As the KGSSHV is balanced XLR, I‘d suggest to use ADI-2 Pro’s 1/2 Main out XLRs for it.
• The Hypex NCore is unbalanced.
So you could use the PH 3/4 front output for it, with a fitting adapter cable, 1/4” TRS stereo –> (2x RCA, I guess), or whatever NCore has.
If you have a cable with angled TRS it looks nicer, not sticking out.
This way you can switch the outputs without unplugging and via remote, and still can plug dynamic or planar-magnetic headphones into PH 1/2 front in case you want.
