1 (edited by lukas108 2023-02-03 14:09:38)
Topic: RME UFX - AES/EBU loop record OUT->IN, possible?
Hi
I wanted do some tests, and need to record from port AES/EBU OUT on AES/EBU IN.  I have connected XLR cable, routed in DAW output on AES L/R  OUT but see no signal on AES L/R IN.
What I missed?
Thanks for help.
2 (edited by waedi 2023-02-03 14:18:57)
Re: RME UFX - AES/EBU loop record OUT->IN, possible?
Did you routed that signal also in Totalmix ?
You have to open Totalmix and route the signal from the DAW in the middle row (software playback channels) to the AES output (bottom row hardware output channels).
Hi Thank you for reply.
This is what I have set  https://youtu.be/hdXZeHj8m9U
Do you see any mistakes there?
I'm not sure if it is a mistake, why is AES input set to Adat2 ? Shouldn't be AES input ?
And clock source is set to AES input ? Set it to internal.
Yes, you're right! This was the reason. Bad AES input in driver panel. Thank you smile
