Topic: Fireface ii midi conection issue
Hey guys,
i am wondering if someone could help me out or has an experience with conecting midi cables into a Fireface ii. Here is the issue,
I have a Strymon Timeline pedal that requires a software update, i had to buy two specific midi cables in order to make this update work. However, it seems like i have a conective issue. Fist off my Fireface ii has both adat IO's in use with two Behringer Ada 8200's. I also am using my Kemper Spidif ins and outs to the Fireface's AES-EBU IO's. In my Madiface settings i see my Adat's and AES are synced and i see this on my Fireface via green lights on the front pannel.
My issue is, when i connect the pedal via midi i have a blinking yellow light, i then checked the Strymon software and i have no incoming signal. The software cannot find the pedal. All the connections are correct but i am stumped on why midi over my Fireface is not connecting. Any ideas guys? I would appreciate any advive or help you guys have.
