1 (edited by Labdoc 2023-02-20 02:42:08)
Topic: Headphone amp/interface to UFX+ 10-15m away
Please advise on how to connect a UFX+ to phones located 10 - 15m distant in the same room.
This is a hifi listening room, not a studio. The UFX+ is located at the front of the room, connected to the amp. My listening location is a desk at the back of the room. A Thunderbolt cable connects the UFX+ to a computer at my desk. I run TotalMixFX and a convolver program for digital room correction via the computer. Works nicely for the main speakers.
Digital input for music playback goes to the SPDIF input of the UFX+ from a headless minicomputer controlled by a web interface (Daphile version of Logitech Media Server (SlimServer)
I would like to add a headphone listening capability beyond Windows audio.
A legacy UFX is available, but I think the ADAT connection is too long.
An ADI-2 pro FS R BE would be elegant, but is a connection possible?
Thanks in advance
ADI-2 pro fs be; UFX+; MADIfaceUSB; Startech active USB3 cable; Sonnet Allegro Pro adapter; Win11x64
Re: Headphone amp/interface to UFX+ 10-15m away
I used the cheapest toslink cables 20m from the house to the garden shed, no problem at all.
The ADI-2 Pro has plenty of connections, AdAT or AES with XLR cables will work.
I love the ADAT cables because they are thin and lightweight.
Easy to hide in the living room.
Thanks @waedi. Problem solved!
I also found some other posts on the forum, mostly by @Ramses, that confirm 15m optical cable is no problem (Toslink in his case).
4 (edited by ramses 2023-02-20 19:27:36)
Longer cables might have an issue with 192 kHz, but might still work at lower sample rates.
According to the standard, TOSLINK cables may be up to approx. 10 m long.
Astonishing, many cable manufacturers offer TOSLINK cables up to 20 m like this one:
https://www.thomann.de/de/mutec_optisches_kabel_20m.htm
But possibly, there might be issues at higher sample rates, maybe also depending on the quality of the TOSLINKs (with the optical converter) on the board.
Assumption: perhaps RME uses TOSLINKs of better quality, so that even 192 kHz is possible over (in my case 15+1) 16 m.
In contrast to that: USB3 cables can't get much longer than 3 m in comparison, so not longer than the standard allows.
Hi Ramses, generally I do not use 192 kHz.
For my info, is the AES/EBU connection over 10-15m any better than Toslink?
6 (edited by ramses 2023-02-20 21:53:06)
AES max cable length is 100 m. It's not better, both allow lossless transport of digital data.
