Topic: Suggestion for Speaker / Studio Monitor Upgrade
Dear RME Forums community,
This is David. Hope I'm posting in the correct section.
I currently am using a pair of KRK Rokit5 G4 with my Babyface Pro FS. Now hoping for a speaker upgrade, because of the noisy amps in the KRK, and also I want to upgrade to a pair of speakers that would better reflect the details output by the DAC chip on my Babyface Pro FS. What speakers do you recommend?
Here's what I'm looking for:
1. Must be active / powered and the amplifiers should be as quiet as possible;
2. I live in an on-campus appartment and the laptop is in the bedroom, so I can't use a big floor standing speaker. However, I still hope the speakers can be as full range as possible. So, no standalone subwoofers if possible;
3. I don't mind DSP or analogue;
4. The idea of a pair of 3-way coaxial speaker set sounds charming, but is it really better? I don't know. If it is, then that would also be something I'm looking for.
I listen to mainly classical music, so everything from chamber music, to piano, to big orchestra and choire and pipe organ. I also like jazz trios and vocalists like Frank Sinatra and Ella Fitzgerald. I also enjoy Broadway musical cast recordings. That's what I mainly listen to. Besides this, I run piano VST instruments and play with my piano style midi keyboard controller and listen through the monitor speakers.
Thanks, and your ideas are welcome!
David
