Topic: Firmware update to 2023-03-24 release, UCX is crashed with all leds on
Yesterday I updated my UCX Firmware to latest release (dated 2023-03-24). Everything went right during flashing process. When finished, I plugged the UCX off and on and ... all leds turned on, green leds blinking.
I use a PC with Windows 10 pro, UCX driver is 1.224.
If I connect it to another PC with same driver and  OS : same malfunction.
If I connect it to my wife's Mac Pro ... ditto !
If I disconnect the USB port, the UCX seams tp work : the channel's green light turns on when I send an audio signal into it.
The UCX is not intensively used and is only 2 years old (february 2021).
Any clue, anyone ?
Thanks in advance for you help.
Patrick.
2 (edited by christo.k 2023-03-25 20:30:22)
Re: Firmware update to 2023-03-24 release, UCX is crashed with all leds on
Hello all,
Same problem here !!!!!!
Card is not recognized from system anymore !!!!!!!! Windows 10 pro x64, driver 1.227.
Please tell me what can I do? What is happening ?
Chris
The flash update is bricking UCX's - would you consider posting this in the other thread too? Might help get RME's attention, they need to pull this update imo
https://forum.rme-audio.de/viewtopic.php?id=37108
