1 (edited by stustu 2023-03-26 19:56:48)
Topic: Fireface 400 and M2 Macbook
There is a post here that shows it's possible to run FW400 devices with the current software, which I was pleased to see:
https://forum.rme-audio.de/search.php?s … 1322634746
But I was wondering whether anyone has any suggestions of a more direct route, since I don't have any FW800 devices to bridge to Thunderbolt. So if possible, I'm looking to use the Fireface with the M2 MacBook, with a single cable if that's possible, or as few adaptors as I can.
The FF400 was such a great sounding interface, and after a long hiatus from music production, I'm happy that it works at all. Be nice to skip a FW800 device in the middle though.
Thanks in adavnce.
Re: Fireface 400 and M2 Macbook
You can get a 9-pin to 6-pin (FW800 to FW400) cable, then you do not need the extra adapter. You will need an external PSU connected, this Thunderbolt connection does not provide sufficient bus power.
3
To make this more clear, you will still need both the Apple USB-C to TB2 adapter and the TB2 adapter to Firewire. No way around that if you don't have a TB 3/4 to FW unit or dock (docks with FW no longer exist).
I've followed the instruction and was able to configure my FF800 to a Mac Mini M2 with the TB4-»TB2-»FW setup. It seems to be working perfectly but I am wondering, since it's a Qlab setup for a theatre, if this setup is really "showproof". Going through 2 adapters rings a bell for me. Has anyone tried this setup for a long time and can tell me about the stability of it?
