Topic: UCX II: Question/Suggestion for gain setting
Hi
Today, I got my UCX II - other than my UFXII and FF800, which are installed in my studio to my perfect satisfaction, this one is supposed to run mostly in standalone mode using DuRec at home and on location . That's where my question originates:
I know how to adjust gain in standalone mode. Unfortunately, when trying to adjust gain to a get decent level, this is a constant going back and forth between each channel's individual settings and the main screen, checking the small level meters (which are sufficient for me for that purpose). As you sure can imagine, this can get annoying.
Of course, in a fixed setup like in my studio, I work with Total FX and can adjust gain whilst looking at the level meter without any back and forth.
My question is: is there a way how to change gain for a selected channel with the encoder knob whilst the front display shows the level meters? As far as I understood the manual: no (I hope I did not miss anything!)
So my suggestion is: please give us a mode, where in "level meter display", we can use the encoder knob to scroll horizontally to each channel/level meter, push the knob to select that very channel, do a gain adjustment by rotating the encoder knob, and push it again to store the gain setting and leave the adjustment function to go on scrolling through the display to the next channel/level meter. All other settings for the channel still can be done in each channels individual setup page, gain being the one that imho is vital to be adjusted looking at a level meter.
Or, alternatively, if the above is not possible: when being inside each channel's individual settings page and selecting to adjust the gain, then please show us a level meter for that very channel at the edge of the screen or a horizontal level meter below the gain level display - then we could still see the value of the gain setting AND check the level meter.
Thanks for discussing or even considering this.
Kind regards!
