I am also doing such kind of things, but without issues.
I am using an UFX+ as well for things like creating a parallel effect loop, adding external FX (PCM81, PCM91).
I would guess you have an issue with levels if you use a high gain amp, but not with USB.
Older version of my setup here
https://www.tonstudio-forum.de/blog/Ent … -DURec-DE/
Now stereo setup with two Marshall combos and the two Lexicons, see drawing below.
Using it as well for re-amping, but only in rare cases. Mostly when looking for proper mic position at the amps (2x2).
Example recording:
https://www.tonstudio-forum.de/attachme … orrow-mp3/
Setup:
Guitar PCM81 PCM91
Inst || || || ||
*****UFX+*****************
Guvnor | | |
| EffSnd EffRet EffRet
Marshall L---+ ComboL ComboR
Signal Chain:
Guitar---UFX+---Guvnor---Amp---EffSnd---UFX+---PCM81/91(100% Wet)---EffRet (Guit+FX)---ComboL/R
Can also be used for reamping, as I am plugging the Guitar into Instr Input and record the pure Guitar Signal as well.
Which sounds btw like this unprocessed (no Amp, no Amp VST) when using e.g. Jazz Guitar like in this case:
https://www.tonstudio-forum.de/attachme … -320b-mp3/
Reference Levels used at the UFX+:
Analog Out to Guvnor: -10 dBV (consumer level)
Amp Effect Send to Analog In: Lo Gain (max headroom, the highest insensitivity)
UFX+ to External Effects: +4 dBu
External Effects to UFX+: again Lo Gain (max headroom, the highest insensitivity)
UFX+ to Effect Return (Power Amp of Combo): -10 dBV (consumer Level)
I keep the levels low for silent recording, so that the amp doesn't get too loud.
