1 (edited by tdc 2023-04-21 06:22:21)
Topic: [Solved] TotalMix meters Bug? Displaying incorrect data
Totalmix is showing some incorrect data on one of the channels. The Meter graphic is showing level for what would be around -20dBFS, but there is no signal preset at that level. The numeric display in TM is showing the correct level -101dBFS.
https://i.ibb.co/nQty6Wg/tm-meter-bug.png
My system is an DigiFace AVB, AVBTool and 2 x 12Mic AVB's. All software and firmware are the latest. The Web control app shows no level being sent to the DigiFace, and on the Mac, DigiCheck NG also does not show any level.
TM: v1.80 MacOS (3)
DFAVB: v244, Driver: v3.28A
If I toggle 48v or adjust the gain, the meter does change, but then moves back to this middle position.
Thoughts?
2 (edited by ramses 2023-04-21 06:24:17)
Re: [Solved] TotalMix meters Bug? Displaying incorrect data
It would be better if you would explicitly name firmware and driver versions. It is mandatory for providing support esp. in such a case.
A few seconds, hours, days, or weeks later, "the latest" is not the latest anymore and then the version information in this thread is vague, can be misleading for the reader and is thus of no value.It's also possible that you only think you have the latest. So, please, use real numbers.
BR Ramses - UFX III, ADI-2 Pro FS R BE, M-1620 Pro D, 12Mic, XTC, RayDAT, Win10, X10SRi-F, E5-1680v4
3
Does the number change when you use RMS On or Off? Does the number change with setting PostFX On or Off? Both under 'Level Meters' in the right blue panel.
Did you try things like resetting TotalMix or such?
5 (edited by tdc 2023-04-22 02:06:03)
Yes, the numeric display shows the RMS value matching the Meter Bar ( -22dBFS)
Further testing shows some interesting behaviour.
• Duplicating this AVB Stream into other Inputs on the DF AVB does not duplicate this behaviour.
• Patching this channel (ch9 on the 12Mic) into other AVB stream channels does not result in this behaviour.
• Any channel from the 12Mic into this channel of the DF AVB results in this behaviour. (ruling out a DC / Preamp issue)
• Unpatching the 12Mic from the DF AVB Stream removes the issue.
• Connecting other 12Mic or AVBTool mic inputs to this stream and channel on the DF AVB does not exhibit this behaviour.
It seems that Totalmix is reporting an incorrect RMS on this channel, and this channel only, regardless of source of input. As previously mentioned, neither the AVB Web interface nor DigiCheck NG show this issue.
I should add that I am at 96kHz, and that this input on the DF AVB is Stream 2, channel 9. TM Channel 21
6
As you used DigiCheck NG: please use the Bitstatistics & Noise instrument to check for DC.
It might also be useful to record the input signal and confirm in a wave editor that there is indeed no signal above -100 db anywhere.
I didn't think DigiCheck NG had this instrument - doesnt appear to be an option.
Did this and the resultant audio file shows a an RMS of -117, and a peak of -101
Here is a movie of the behaviour.
https://i.ibb.co/478YdX6/tm-bug.gif
What is being shown is TotalMix channels 21-22, which are receiving AVB Stream #2, Ch 9 and 10.
I have patched the 12Mic output CH9 into the Stream channels 9 & 10 so both these two TotalMix channels are receiving the same content over AVB. You can see that they are different.
I start with no 48v or Gain. Then I switch in 48v, then add a mic, and add some gain, then pull the mic out and switch off the 48v.
8
Current DC NG version is 0.891, it has that instrument. Latest one is here:
https://forum.rme-audio.de/viewtopic.php?id=37298
To avoid damages on your equipment you really shouldn’t plug in/out the mic with activated phantom power!
10
Here is the same source patched into AVB Stream 2 - Ch's 9 & 10, appearing on the DF AVB on Channels 21 & 22.
https://i.ibb.co/GkqSQxK/DGNG.png
11
Thanks. We will try to reproduce and research how this is happening.
Please try the latest Version that is v254
13
Spent some time today updating and re-flashing all devices in this system, and this appears to have resolved the TM meter issue.
Many thanks.
