Topic: ADI-2 DACs - can you bypass its DAC?
Can you have the option to bypass the D/A conversion by ADI-2 DAC if one wants to use the unit as a pre-amp of sorts and use an external DAC sometimes? Should digital input to digital output into external DAC do the trick here?
