Topic: Startech 3m USB 3.0 M/F Active Extension Cable
This 3m active USB extension cable works well with UFX+
https://www.amazon.de/gp/product/B007B6 … 8&th=1
Runs since 1h flawlessly without any USB transport error.
The cable lays much better compared to the much more expensive corning optical cable and is less expensive.
I bought a 2nd one for USB2 (should be compatible) to also connect the ADI-2 Pro via USB.
With the 3 m active extension cable as base, I can get any required length between 3.5 and 6 m adding a normal USB3 cable of 0.5 - 3 m length.
Thanks to the one mentioning this cable here on forum. It is much better than the corning optical cable, which is from a handling perspective a catastrophe and creates plenty of ugly cable loops on the floor. Even worse, the corning cable for around €150 was not working anymore after only 3-4 months of use (without any stress on the cable).
