Thanks for correction, indeed I thought the DAC chip could do ADC as well, but it's another chip.
I just looked into the manual, and found that the second DAC chip is basically only used for headphones 3/4, so I never use it.
Overall, this is now still a bit unclear to me, I mean I've been hearing this clearly. But I always used the preamp mode to monitor. I never used the AD/DA mode. Is it better?
Because in the manual I found:
"... In DSD mode the DSP performs an additional DSD to PCM conversion, to be able
to show the audio signal on the level meters and for the Analyzer – another unique feature of the
ADI-2 Pro."
Also Preamp mode:
"... The below diagram shows that the analog input is sent to all digital outputs simultaneously. Any
DSP setting (EQ, phase etc.) of the analog input will affect all outputs. ..."
For the AD/DA-mode, no such statement is given?!
So you are saying: "DSD is converted and downsampled for the meter- and analyzer-display only, this works independent from the audio monitor."
Generally, it makes sense to me, that the DSP is not used for DSD monitoring, but does that hold true for the preamp mode? Also while studying the manual, I found that both the DSP as well as the DAC is capable of converting DSD to PCM, which makes sense in regards to the DSD Analyzer, but is a source of confusion. On the other hand, probably the DAC conversion is of higher quality, such that I didn't hear the same level of difference when toggling "DSD direct", as I hear while monitoring DSD via the preamp mode!
"And here’s the “sound difference” between DSD-PCM and DSD direct (ADI-2 Pro only):
DSD direct is 1dB quieter than DSD-PCM!"
Yes, I see that, it's always at -1 dB for me during DSD recording/playback.
Too bad, the ESS DACs don't offer "DSD direct", but I cannot tell how they sound, I never listened to them. Different chip manufactures have different strategies and that's fine. I know 1-bit DSD is not the only way for high-resolution PDM audio, I think that's what ESS is doing? Multi-bit PDM.
