Topic: Asio Driver not active Cubase 11
Today I switched from my 2008 Fireface 400 to a Fireface UCXii.
Was immediately detected and could play music (Apple Music). Steinberg VST live also works (MIDI).
But in Cubase 11 I can not playback or record. It says "Asio Driver is nor active"
My USX ii is connected via SPDIF and Wordclock to Mytek converters.
Here some screenshots:
https://www.dropbox.com/sh/uxm845cqp8og … RKvIa?dl=0
Thanks for helping.
http://www.nantschev.com
http://www.crystalhorizon.at
2 (edited by waedi 2023-05-23 03:35:03)
Re: Asio Driver not active Cubase 11
Foto 2 ASIO driver, what else can be selected ? Core-Audio ? Select Core-audio.
You are on a Mac computer and ASIO is a Windows audio system.
Mac has built in Core-audio wich is the audio system you have to use.
Then in the Mac system preferences Audio device, select the RME as input and output device.
M1-Ventura, Madiface Pro, Digiface USB, Babyface silver and blue
This is what I can select: https://www.dropbox.com/s/xzbxenm3viafo … 6.png?dl=0
When I choose a different driver, I can't choose my inputs and outputs in my DAW
Did you this :
Then in the Mac system preferences Audio device, select the RME as input and output device. ?
Did you this :
I managed get it running: I installed the previous driver (written kernel) this did the trick!
6
That reminds me:
https://forum.rme-audio.de/viewtopic.ph … 69#p188269
