1 (edited by Sciss 2023-05-29 16:07:46)
Topic: smaller / softer case for the Babyface Pro FS
Hi there,
I have tested the Babyface Pro FS in our lab, and it's there with its original hard plastic container, which I find quite horrific (low quality, not very accurate fit, too large). I'm kind of surprised that at this price point, no more thought went into a transportable case. So my guess is, most users will swap that case for a different bag or case. I saw that RME even made a soft bag for the original BF (BF-BAGBK), but the original BF was also a cm less in each dimension, so might not be a good fit.
Something tightly nicely fitting with padding, that you can safely put in a rucksack or hand luggage. Any recommendations or thoughts?
Re: smaller / softer case for the Babyface Pro FS
Well, I guessed the Wicked Chili GOP Case M would be suitable:
https://i.imgur.com/K6YlqA3.jpeg
and indeed it works, although it could have been 1cm less wide.
