Topic: Screechy/distorted "digital" sound through USB. ADI-2 DAC FS.
The sound is similar to a fax or old school dialup modem, but higher pitch and more annoying. I have had the DAC for a few years, with no issues.
I recently installed the ASIO output component for Foobar 2000 on my laptop, which is connected to the DAC via USB.
I was doing A/B comparisons of CDs (through CD transport hooked up via coax to DAC) and the FLAC files I created from them. They are on a laptop used solely for that purpose.
I started a song on both sources at the same time, and was using the RME's remote to switch between the 2 inputs. The "distortion" started quietly, barely noticeable, but got worse every time I switched between the transport and back. More of the music was replaced by the "screeching" sound each time.
It very quickly became painful to listen to.
I stopped the song, and when I started it back up, it was fine, until I switched inputs again a couple times and the screeching came back. I then closed Foobar and reopened it, I didn't notice it, but I only flipped inputs a couple times. I was frustrated and walked away.
Any thoughts on the problem?
