Topic: Can't Monitor Mix with UFX+
I hope I can get a answer here to a issue I'm having and it may be me just not understanding how Total Mix works. I'm using a UFX+ bussed to a analog summing unit which is going through a ADC that is going back into the UFX+ via AES. The problem is I can see the signal hitting the AES channel but I can't hear it or in other words I cant mix through it. I've tried to wrap my head around the loopback feature but I'm not sure if that applies. I just want to be able to hear what while I'm mixing into the summing and ADC. The AES channel is routed to the 1/2 main but that does not give me the ability to hear the processed signals.Any information or tips on this would be greatly appreciated. If it's something simple that I'm overlooking maybe another set of eyes would help. Thanks!
