Topic: Fireface Settings app continuously launching/quitting
Hi all!
Hope you're doing well!
Last month, I purchased a new M2 Mac mini. This week I set it up as my DAW system with a Digiface USB as the audio interface.
I followed the driver installation process (I successfully did the system permission procedure) but after a while I started experiencing a weird issue.
There's some kind of disconnection/re-connection of the Digiface.
The Fireface Settings app is continuously launching and quitting. It happens randomly and repeats until I unplug/re-plug the interface. After a while, it happens again.
I tried to change USB port but the issue remains. By the way, the interface is directly connected to a USB port. No dongles, etc. There are not connection issues with other devices like ssd drives, midi controllers, a small Audient interface, etc. I also tried to connect the Digiface to an Intel Mac and I couldn't reproduce the issue.
I believe the problem comes from the combo of the Digiface and the Mac mini but I ran out of ideas on what else to try.
Is there anything that I'm missing? Any setting or extra updates?
macOS version: Ventura 13.4
Driver version is 4.08
Firmware version is 18
Thanks!
Re: Fireface Settings app continuously launching/quitting
First thought : cable is broken.
But you say on the intel mac it's working fine...?
I would try another cable
and check the security and privacy settings microphone if Totalmix is enabled.
3
Settings dialog opening and closing simply means USB disconnected/reconnected -> USB issue.
Hey all!
Thanks a lot for your replies!
Could you please elaborate more on this?
Thanks for the input!
Yes, I'm assuming the same but is there anything I could do to verify the side of the issue?
As I said, I don't have disconnection issues with other external devices when connected on the same port and at the same time I don't have disconnection issues with Digiface on an Intel mac. So I'm in a confusion state. Any idea?
Did you try with a headphone on the Digiface ? wondering if a higher energy consumption has an effect on the issue...?
