Topic: Wonderful video on linearizing headphones
Many thanks to you and your colleague, MC! This new video on using the EQ of the ADI-2 series for linearization of headphones is super helpful and has yielded excellent results on my Beyerdynamic DT1990 Pros with Dekoni Elite Velours earpads:
**Mod edit: updated link to video** https://www.youtube.com/watch?v=_Nq9ZGAYTwU&t=541s
Brass-heavy orchestral works in particular sound magnificent. A fun demo:
https://www.youtube.com/watch?v=NkqnJlHgz24
Re: Wonderful video on linearizing headphones
...includes a tease of the new power supply!
3
Congrats - first to notice it smile
Nice video! When he talks about the HD650 around 02min 21sec the graph is from a beyerdynamic with the nasty treble peak.
5
Oh no! Well, we fixed that and will exchange the video with the corrected one. Unfortunately YouTube does not allow in-place changes, so the video will have a different URL and looses all current comments/ratings. But better this way than having it wrong and confusing already on the beginning and then forever...
Nice. The reddit link gives a frequency response graph for nearly all Headphones. Even for my DT990 (which i did not find at the manufacturers page).
And thus i do not own an ADI-2 whith such details about the EQ - In TMFX i tried to adapt the 3-band EQ settings in my Fireface 802s Phone OUT (as good as possible).
Result may be not as perfect as the ADI-2.
But the first impression - seems to be more clear.
Thanks for the inspiration!
“Do It For Her”
7
The video has been fixed and reuploaded:
Great video! thanks Matthias. It would be great if users could upload more ADI-2 presets to extend the headphones list. I'm working on similar (to my taste) profiles for Sennheiser HD280 pro and Grado SR125i. I will share as soon I feel they are ready.
9 (edited by KaiS 2023-06-25 00:24:02)
I’m glad the video is pointing on the fact that very high-Q filters usually don’t improve sound and could/should be abandoned.
One has to be aware, a correction can’t be more detailed than the, largely smoothed, target curve the published measurements are based on.
Thanks for the great video! Also in the reupload at minute 10:06 there is still a Sennheiser plot instead of the Beyerdynamic.
Cheers, Ernst
ADI-2 PRO FS R BE / ADI-2 DAC FS / some old multibit treasuers ;-)
11
In fact it was correct before. Sigh...
HD820?
As soon as the app is out for Windows I am sure we will see tons of EQ files floating around everywhere. The exported .adieqpr file (see my example set) is below 2 KB only, easily editable even outside the ADI-2 Remote (xml). We should end up with a big library (big in number of files, but small in size) of adieqpr files of most headphones on the market. And more.
<ADI-2DAC>
        <General>
            <val e="Version" v="2"/>
        </General>
        <EQPreset3Left>
            <val e="EQEnable" v="1.00,"/>
            <val e="EQBand1Type" v="0.00,"/>
            <val e="EQBand1Gain" v="-5.50,"/>
            <val e="EQBand1Freq" v="180.00,"/>
            <val e="EQBand1Q" v="0.50,"/>
            <val e="EQBand2Gain" v="-2.00,"/>
            <val e="EQBand2Freq" v="1130.00,"/>
            <val e="EQBand2Q" v="1.40,"/>
            <val e="EQBand3Gain" v="-3.00,"/>
            <val e="EQBand3Freq" v="3100.00,"/>
            <val e="EQBand3Q" v="3.00,"/>
            <val e="EQBand4Gain" v="-1.00,"/>
            <val e="EQBand4Freq" v="5000.00,"/>
            <val e="EQBand4Q" v="6.00,"/>
            <val e="EQBand5Type" v="0.00,"/>
            <val e="EQBand5Gain" v="3.00,"/>
            <val e="EQBand5Freq" v="10500.00,"/>
            <val e="EQBand5Q" v="1.40,"/>
            <val e="BassTrebleEn" v="0.00,"/>
            <val e="EQBassGain" v="5.50,"/>
            <val e="EQBassFreq" v="105.00,"/>
            <val e="EQBassQ" v="0.70,"/>
            <val e="EQTrebleGain" v="-5.00,"/>
            <val e="EQTrebleFreq" v="10000.00,"/>
            <val e="EQTrebleQ" v="0.70,"/>
            <val e="DualEQ" v="0.00,"/>
            <val e="EQ Preset Select" v="0.00,"/>
            <val e="Load BT w. EQ" v="1.00,"/>
        </EQPreset3Left>
        <EQPreset3Right>
            <val e="EQEnable" v="0.00,"/>
        </EQPreset3Right>
        <PresetNames>
            <val e="EQPresetName3" v="HD650"/>
        </PresetNames>
    </ADI-2DAC>
As a new user I found the video informative, especially the use of 'Load B/T' to make a 7-band PEQ for Oratory1990/HD650.
However I was trying to use this in conjunction with Dual EQ, setting a different high shelf in Band T for each channel. (I have HF hearing loss on one side.) I found that any parameter adjustment of Band T (or Band B) in Phones L was mirrored into Phones R (and vice versa).
Am I correct in assuming that Dual EQ can only store L/R EQ settings for the main 5 bands, and that Bands B & T are always common to both channels?
14
You are correct.
15 (edited by ratty 2023-06-27 21:17:57)
You are correct.
Thanks. I've worked around it by adjusting the Oratory1990 settings down to 5 bands.
