1 (edited by TWY 2023-06-24 05:26:44)
Topic: Optical2 is AES/SPDIF - Signal routed to AES channel - still no sound
I'm using the UFX+, via USB3.
My setup is such:
Optical 2 out via TOSLINK cable, to a digital-to-analog adapter, and then from the adapter output, to my computer speakers.
My settings on the UFX+ are:
Optical 2 OUT set to AES/SPDIF. "Consumer" or "Professional" doesn't seem to make a difference.
On my computer, I have designated the sound as coming from "ADAT 7+8".
on TotalMix, I've also already routed the signal on the AES channel with "ADAT 7+8".
I'm still getting NO sound from my computer speakers.
Is there anything I'm doing wrong here?
Any help would be much appreciated!
Re: Optical2 is AES/SPDIF - Signal routed to AES channel - still no sound
Plug the optical cable not into the DAC, but back into the UFX+ and check that there is really an audio signal. If so the DAC is at fault.
Yes, I can confirm that there is an audio signal. The TOSLINK cable has red light from coming from the other opposite end from where it's connected to the UFX+.
Perhaps a faulty DAC. Let me get a new DAC and I'll report back.
Thanks.
Did you see level at the respective TM FX input channels? Did you listen to it via the UFX+ input monitoring? Did you check the input's status in the Settings dialog?
5 (edited by TWY 2023-06-24 10:33:59)
Yes, I can see the metering levels in TM FX. Both "ADAT 7+8" and the AES channel has a meter signal. Which means the audio signal should be there, correct?
How do I check the input monitoring? Also, what does the input in the Settings dialog have to do with what I'm trying to achieve - which is output to the DAC?
I think this refers to the "loopback" test of your optical port to see whether it's working before further troubleshooting the connection of the connected device.
7 (edited by TWY 2023-06-24 10:41:53)
Oh, I see! Apologies for the misunderstanding. Yes, I just tested the loopback. I plugged the the TOSLINK cable from "out" back into "in".
I see a signal at the AES input in TotalMix FX, which means there's an audio signal going out and back into the UFX+.
Which means, the UFX+ should be in working order, correct?
And then you can check two things with such a loopback test
a) whether you see not only "lock" but the more important "sync" status
b) you can then route audio to all 8 ADAT outptut channels (8 at single speed) and then observe whether all 8 ADAT channels are also visible on the HW inputs ADAT x..y (1-8 or 9-16 depending on whether this is ADAT1 or ADAT2).
okay. But since I'm getting a physical audio signal through the loopback, I have a strong feeling this problem has nothing to do with the UFX unit. The cables connecting the UFX+ and the DAC are all new as well.
I think it's a faulty DAC. I'll be receiving a new DAC tomorrow, will check and see how it goes. If it still doesn't work, then I'll do more tests like you mentioned.
Thanks.
10
I knew it!
Just got my new DAC, and now everything works. So it was a faulty DAC afterall.
Anyway, thanks so much for your troubleshooting help, guys!
Solved.
Great, thanks for the good news and the positive feedback!
