Topic: Totalmix output EQ bug - causes DC offset on Babyface Pro FS
G'day,
I mis-typed a value applying corrective EQ to my monitors and found a bug in Totalmix's output EQ, causing a DC offset from the AN1/AN2 XLR outputs of a Babyface Pro FS.
I can consistently replicate the behavior doing the following:
1. Set main output as AN1/AN2
2. Enable EQ
3. Drag HF shelf to +6dB with the cursor
4. If I enter an exceedingly high value of ‘50000’, the pot sticks to it’s upper-threshold of 20k.
5. Use the mouse to click and drag the value back to 19.9k.
6. Then enter ‘000’.
Band 3 frequency will now show as '0'. Clip lights will illuminate in Totalmix.
During some tests, I've had loud, repeated popping noises through my monitors - about twice a second.
In other instances, there's only been a single pop.
A multimeter tied between pin 1 and pin 2 of the output shows a DC offset of ~860mV.
Particulars as follows:
TotalMix FX Version 1.83 macOS (1)
Firmware: v203 (also confirmed in v205)
Driver: 4.08
macOS Monterey v12.6.5 (also confirmed in Monterey v12.6.6)
I've uploaded a video demonstrating the problem here:
https://www.dropbox.com/s/98cfkfpwp2fmk … g.MOV?dl=0
Additionally, as a secondary issue - since moving to the DriverKit driver, I'm getting ‘Fireface USB Settings quit unexpectedly’ if I unplug USB from the Babyface Pro FS while the system is running.
I've also raised this via the support line of the local distributor.
Cheers,
Andrew
2 (edited by alye 2023-06-27 07:26:41)
Re: Totalmix output EQ bug - causes DC offset on Babyface Pro FS
Also worth noting, if anyone reading this thread does try to replicate the problem. I wouldn't advise doing this with your monitors connected as the sound may be loud and/or cause damage to your speakers.
3
000 Hz or 0 Hz entry is invalid. We will better limit the range to the intended areas so this can't happen. Thanks for reporting.
Thanks Matthias, appreciate it.
5
You can try this with version 1.85 beta 1. It should prevent you from getting these unintended results:
https://www.rme-audio.de/downloads/tmfx_mac_185b1.zip
